Up to 20% off select tools
Install Ubuntu 16 on the Pixel
Views: 4.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
99
All Time:
4,357
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to setup Ubuntu Linux on your Chromebook Pixel without flashing your BIOS.
A word on flashing...
You may choose to remove the Write-Protect screw and tinker with the BIOS or flash it in the future. Note that I am not responsible for any mishaps that may arise from that.
    1. Install Ubuntu 16 on the Pixel, Enable stuff!: step 1, image 1 of 2 Install Ubuntu 16 on the Pixel, Enable stuff!: step 1, image 2 of 2
      • Enable Developer Mode/Legacy Boot
      • As mentioned before, you don't need to flash your BIOS, we'll just use the stock SeaBIOS.
      • This means you'll have to press "crtl" + "L" on each boot
      • It'll take some time so grab a coffee while you're waiting...
      Ask FixBot
    2. Install Ubuntu 16 on the Pixel, Boot up Ubuntu: step 2, image 1 of 1
      • Unlike the Windows installation, you don't need a USB keyboard or mouse to boot the OS
      • Select your USB installer drive on startup
      • You should get the Ubuntu startup screen
      Ask FixBot
    3. Install Ubuntu 16 on the Pixel: step 3, image 1 of 2 Install Ubuntu 16 on the Pixel: step 3, image 2 of 2
      • I highly recommend you connect to Wi-Fi before you continue to get all the necessary drivers
      • The Wi-Fi card is automatically detected on boot
      • Just step through the installer like you would with any other distro
      Ask FixBot
    4. Install Ubuntu 16 on the Pixel, Reboot: step 4, image 1 of 1
      • Remove your installation media and reboot when prompted by Ubuntu
      • On startup, login to your account and setup your hotkeys to enable volume (mute, decrease, increase).
      • Display brightness can be fixed by setting up a custom keymapping:
      • sudo apt-get install xdotool
      • name: Brightness Up command: xdotool key XF86MonBrightnessUp
      • name: Brightness Down command: xdotool key XF86MonBrightnessDown
      Ask FixBot
You're done! If you ever want to get back to ChromeOS just create a recovery drive in your Chrome browser and enable secure boot at the Pixel startup.
Author
with
Kevin Fessler
1,887 Reputation
4 Guides authored
2 Guide Comments
Trying to do the brightness key map .I did this sudo apt-get install xdotool.What do I do next i cant seem to find the app xdotool ?
wesley tejeda - Reply Share
Does it support the light bar in any way or is there a way to enable it
Naru Fox - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 99
All Time: 4,357
