Up to 20% off select tools
Insta360 One X2 Camera Lens Replacement
Views: 26K
View statistics:
Past 24 Hours:
7
Past 7 Days:
55
Past 30 Days:
261
All Time:
26,053
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 3 hours
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Action cams are going to see action, and the lenses are at risk of scratches. Replacement lenses are affordable, but what tools and facilities do you need for replacing a scratched lens? Kudos to LA Hover Bikes for a super helpful video.
There remain some mysteries about how Insta360 repairs lenses. Presently I feel like I know more about what not to do than what is the best way. Please contribute to this procedure if you find a better way to remove the lens or to seal the new one!
    1. Insta360 One X2 Camera Lens Replacement, Order a replacement lens: step 1, image 1 of 2 Insta360 One X2 Camera Lens Replacement, Order a replacement lens: step 1, image 2 of 2
      • Generic replacement lenses are available on eBay. Shipping can take several weeks. Quality may vary.
      • I've ordered two lenses from different vendors. Neither had the factory optical coating. One had a stairstep grind that causes a scalloping artifact in the image. In the photo, this skylight has a rectangular opening.
      Ask FixBot
    2. Insta360 One X2 Camera Lens Replacement, Protect the good lens: step 2, image 1 of 2 Insta360 One X2 Camera Lens Replacement, Protect the good lens: step 2, image 2 of 2
      • If you are replacing only one of the lenses, then first protect the other lens from scuffs.
      • I used masking tape and a cotton ball to cover and pad the lens.
      Ask FixBot
    3. Insta360 One X2 Camera Lens Replacement, Remove the damaged lens: step 3, image 1 of 3 Insta360 One X2 Camera Lens Replacement, Remove the damaged lens: step 3, image 2 of 3 Insta360 One X2 Camera Lens Replacement, Remove the damaged lens: step 3, image 3 of 3
      • LA Hover Bikes found the best approach is to break the lens and remove the pieces. In theory the lens could be popped out. The factory uses a lens adhesive that does not release by heat. Alternatively, Life after 40 used a small screwdriver to pry out the lens.
      • A Dremel cutting wheel can be used to score the glass. The "dome" shape of the glass makes it difficult to crack.
      • Take care not to scratch the window covering the imager. Control the break, control overtravel, or overtravel excentric of the central window.
      • The window is not in the focal plane. Small scratches on the window are spread over the image and cause generally reduced clarity rather than defined spots or lines on the image.
      Ask FixBot
    4. Insta360 One X2 Camera Lens Replacement, Note about Heating the Lens: step 4, image 1 of 1
      • If heating the camera, first remove the battery and SD card low-temperature components.
      • I did not have heat gun. I heated a surface to 150F, removed the heat source, and put the scratched lens in contact with the surface.
      • I heated the lens to 150F and I could not tell that the adhesive released. I am routinely skipping this step.
      Ask FixBot
    5. Insta360 One X2 Camera Lens Replacement, Prepare the lens cavity: step 5, image 1 of 3 Insta360 One X2 Camera Lens Replacement, Prepare the lens cavity: step 5, image 2 of 3 Insta360 One X2 Camera Lens Replacement, Prepare the lens cavity: step 5, image 3 of 3
      • Remove excess adhesive. A dental pick or other tool tip could be used. Turn the camera so gravity cleans the cavity instead of filling it.
      • If you remove minimal material, the new lens will snap in snugly. If you are aggressive the lens will fit loosely and need adhesive to hold it in. If you do not remove excess material, the new lens will not seat and the camera will stitch the images with a visible seam.
      • Alcohol may be used liberally to clean the lens. A soft toothbrush or Q-tips may be used. Here I soaked a film of superglue in alcohol and it wiped off.
      Ask FixBot
    6. Insta360 One X2 Camera Lens Replacement, Create a clean work area: step 6, image 1 of 1
      • Any spec of dust or lint on the inside of the lens or in the cavity can show up as a visible defect in all of your video or images. This work would be best performed in a clean-room, but you don't have one.
      • Choose a room with dust-free air. Gravity removes dust from still air. Filters remove dust from moving air. Probably not the same location where you had the Dremel tool...
      • Use cotton balls, rubbing alcohol, or similar to thoroughly clean all dust and deposits from a 2' x 2' sealed/smooth work surface
      • Clean the cavity of the camera with alcohol and a fresh Q-tip and place it upside down to dry.
      • Open the new lens and clean the inside with alcohol and a fresh Q-tip and place it upside down to dry.
      • If the Q-tip is depositing any lint, then open a packaged lint-free lens wipe and clean the camera sensor window and inside the new lens.
      Ask FixBot
    7. Insta360 One X2 Camera Lens Replacement, Install the new lens: step 7, image 1 of 1
      • Ideally, the new lens will snap into place and hold firmly.
      • DO NOT use superglue to seal the lens. Over a few days it will deposit a film on the inside of the lens.
      • Here the lens was loose. I applied a small amount of epoxy to the outside, wiped to remove excess, centered the lens and allowed the epoxy to cure. I do not have a seam in my 360 image.
      Ask FixBot
Finish Line
Author
with
Student4Life
2,925 Reputation
8 Guides authored
6 Guide Comments
From where i could get those lens? Price of 1 lens?
Arun C - Reply Share
Any iFixit for the insta360 x3 camera?
sidd - Reply Share
I managed to remove by X2 lens in a different way - glueing a stick to the lens so that you can break the connection between lens and camera by applying force to the stick.
Details
1. protect the casing and the other lens
2. find a pipe with an outer diameter a bit smaller than the lens diameter (~20mm diameter, 10 cm length). I used a PVC pipe for electrical installations you get in every hardware store.
3. glue it to the lens using epoxy glue. Put most of the epoxy inside the pipe so that it does not glue to the casing, only to the lens. Still you want a large area of the lens covered. Let it cure.
4. break the stick from the camera - if the lens is removed you are finished but in my case the connection between lens and epoxy broke.
5. glue the stick again to the lens using super glue. Super glue is stronger in this case but you need the epoxy as it is not able to fill gaps - due to he epoxy there are no gaps between stick and lens
6. break the stick again from the camera - this time it worked
ogwee - Reply Share
Replacing the lens will not work with the X3.
You need to buy a new module. I learned the hard way
Jens Wensing - Reply Share
For the X3, the lens is held in with a threaded ring, but insta have used thread lock to stop it from turning. What I did was remove the sensor module from the camera, then uses a dremel tool to carefully cut a groove into the retaining ring, making sure not to cut all the way into the threads on the camera module, it's aluminum, so easy to cut precisely. Then use a screwdriver to open up the gap in the retaining ring which will hopefully break the thread lock enabling you to remove the ring. Clean up any metal filings and dust, then the lens should pretty much pull out (no glue holding it in). Make sure new lens is free of fingerprints or dust, and install into camera. Screw down the replacement retaining ring that should come with the new lens. Reinstall sensor module into camera. Job done!
Chay Donohoe - Reply Share
Past 24 Hours: 7
Past 7 Days: 55
Past 30 Days: 261
All Time: 26,053
