Inspiron 7359 2-in-1 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
60
All Time:
821
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with a 13.3-inch (33.78 cm) – HD (1366×768), IPS touchscreen. Consider replacing the screen if:
  1. The screen has dead pixels.
  2. The screen is flickering.
  3. The is screen is cracked.
  4. You simply want to upgrade it.
It's a little intimidating to replace an LCD touchscreen, but if you have the replacement screen, the right tools, and you follow these instructions carefully, you're gonna have your computer looking good very soon.
There's little danger once you power off and disconnect the computer. Just be careful with the screen during replacement, because it is fragile to detach and install. Make sure not to cut yourself on anything either. The screen isn't particularly sharp, but if it's cracked, it may have edges. If the screen is cracked or shattered, follow this guide before you begin as a safety precaution.
Tools
    1. Inspiron 7359 2-in-1 Screen Replacement, Bottom Case: step 1, image 1 of 1
      • Turn off device before starting.
      • Turn the laptop upside down with the logo facing the surface of the table.
      Ask FixBot
    2. Inspiron 7359 2-in-1 Screen Replacement: step 2, image 1 of 2 Inspiron 7359 2-in-1 Screen Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
      Ask FixBot
    3. Inspiron 7359 2-in-1 Screen Replacement: step 3, image 1 of 1
      • Use a spudger to separate the back cover from the laptop.
      • Start from one corner and work your way around the edge of the cover.
      • Be careful not to bend or crack the back cover.
      Ask FixBot
    4. Inspiron 7359 2-in-1 Screen Replacement: step 4, image 1 of 1
      • All hardware components should be exposed.
      Ask FixBot
    1. Inspiron 7359 2-in-1 Screen Replacement, Screen: step 5, image 1 of 1
      • Using a spudger or opening pick, carefully pry in between the screen and the screen backing.
      • After opening the LCD Screen, slowly and carefully open the laptop so the front of the screen touches the keyboard.
      Ask FixBot
    2. Inspiron 7359 2-in-1 Screen Replacement: step 6, image 1 of 1
      • Slowly peel back the tape that is attached to the screen itself.
      • Once the tape is removed, gently disconnect the attached cables.
      Ask FixBot
    3. Inspiron 7359 2-in-1 Screen Replacement: step 7, image 1 of 1
      • Carefully disconnect the attached cable.
      • Once you remove the attached cable, gently lift up the LCD panel.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Dominique
251 Reputation
2 Guides authored
Gateway, Team S1-G3, Saknee Fall 2019 Member of Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 821
