Inspiron 7359 2-in-1 Fan Replacement
    1. Inspiron 7359 2-in-1 Fan Replacement, Bottom Case: step 1, image 1 of 1
      • Turn off device before starting.
      • Turn the laptop upside down with the logo facing the surface of the table.
      Ask FixBot
    2. Inspiron 7359 2-in-1 Fan Replacement: step 2, image 1 of 2 Inspiron 7359 2-in-1 Fan Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
      Ask FixBot
    3. Inspiron 7359 2-in-1 Fan Replacement: step 3, image 1 of 1
      • Use a spudger to separate the back cover from the laptop.
      • Start from one corner and work your way around the edge of the cover.
      • Be careful not to bend or crack the back cover.
      Ask FixBot
    4. Inspiron 7359 2-in-1 Fan Replacement: step 4, image 1 of 1
      • All hardware components should be exposed.
      Ask FixBot
    1. Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: step 5, image 1 of 1
      • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
      • These screws hold the hdd and removing these screws will make it easier to remove it.
      Ask FixBot
    2. Inspiron 7359 2-in-1 Fan Replacement: step 6, image 1 of 2 Inspiron 7359 2-in-1 Fan Replacement: step 6, image 2 of 2
      • Lift the hard drive from the left side. Be careful not pull on it.
      • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
      Ask FixBot
    1. Inspiron 7359 2-in-1 Fan Replacement, Fan: step 7, image 1 of 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: step 7, image 2 of 2
      • Carefully pull the fan adapter labelled one.
      Ask FixBot
    2. Inspiron 7359 2-in-1 Fan Replacement: step 8, image 1 of 1
      • Pull the wire from the hook to make it easier to take the whole fan out.
      Ask FixBot
    3. Inspiron 7359 2-in-1 Fan Replacement: step 9, image 1 of 1
      • Remove one 5mm screw using the Phillips screw.
      • After the screw is extracted use your hands and carefully take the fan out.
      Ask FixBot
Dominique
251 Reputation
2 Guides authored
Gateway, Team S1-G3, Saknee Fall 2019 Member of Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 22
All Time: 737
