Insignia NS-VCS14SL7 Stick Vacuum Power Button Replacement
  1. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: step 1, image 1 of 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: step 1, image 2 of 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement, Stick Vacuum Power Button: step 1, image 3 of 3
    • Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
    • Pull up on the back cover of the vacuum handle and remove it.
    Ask FixBot
  2. Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: step 2, image 1 of 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: step 2, image 2 of 3 Insignia NS-VCS14SL7 Stick Vacuum Power Button  Replacement: step 2, image 3 of 3
    • Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
    • If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
    Ask FixBot
Thibaut Pillot
434 Reputation
5 Guides authored
USF Tampa, Team S16-G3, Boczar Spring 2018 Member of USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 466
