Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement
    1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: step 1, image 1 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: step 1, image 2 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: step 1, image 3 of 3
      • Flip the device over so the back panel faces up.
      • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
      • You may want to use a flashlight during this step, as the screws are hard to see.
      • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
      Ask FixBot
    2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: step 2, image 1 of 1
      • Take the screws out and set them aside.
      • Be sure to set them somewhere flat, so they don't roll away.
      • Gently pull the front panel and back panel apart to open the device.
      Ask FixBot
    1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: step 3, image 1 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: step 3, image 2 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the 1.3mm screw on the black rectangle above the Tip-Over Safety Switch.
      Ask FixBot
    2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: step 4, image 1 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: step 4, image 2 of 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the 0.9mm screw from the back panel of the Tip-Over Safety Switch.
      • Remove the back panel and the Tip-Over Safety Switch.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 629
