Insignia NS-HTMC01-B Power Indicator Light Replacement
  1. Insignia NS-HTMC01-B Power Indicator Light Replacement, Front Case: step 1, image 1 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement, Front Case: step 1, image 2 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement, Front Case: step 1, image 3 of 3
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
    Ask FixBot
  2. Insignia NS-HTMC01-B Power Indicator Light Replacement: step 2, image 1 of 1
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
    Ask FixBot
  3. Insignia NS-HTMC01-B Power Indicator Light Replacement, Power Indicator Light: step 3, image 1 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement, Power Indicator Light: step 3, image 2 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement, Power Indicator Light: step 3, image 3 of 3
    • Locate the bottom left corner below the fan inside of the heater.
    • There is a small black rectangular box with two cables coming out of it.
    • Using a Phillips #4 screwdriver, unscrew the two screws at the base counterclockwise, and set the screws to the side.
    • Be sure to set the screws on a flat surface to ensure they don't roll away.
    Ask FixBot
  4. Insignia NS-HTMC01-B Power Indicator Light Replacement: step 4, image 1 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement: step 4, image 2 of 3 Insignia NS-HTMC01-B Power Indicator Light Replacement: step 4, image 3 of 3
    • After unscrewing the black rectangular box up from the base of the grey frame, locate the small green rectangular light fixture.
    • Unscrew the one screw from the green rectangle counter clockwise, and set the screw to the side.
    • Gently lift the green circuit board out of the socket by pulling on the black and white cables.
    • At the end of the green rectangle is a light-emitting diode (LED). This is what lights up the power button.
    Ask FixBot
  5. Insignia NS-HTMC01-B Power Indicator Light Replacement: step 5, image 1 of 2 Insignia NS-HTMC01-B Power Indicator Light Replacement: step 5, image 2 of 2
    • To replace the LED, unplug the white jack with the black and white cords from the bigger tan circuit board.
    • Remove the LED cord.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 348
