Insignia NS-HTMC01-B Power Button Replacement
    1. Insignia NS-HTMC01-B Power Button Replacement, Power Button: step 1, image 1 of 1
      • Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
      • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
      Ask FixBot
    2. Insignia NS-HTMC01-B Power Button Replacement: step 2, image 1 of 1
      • Find the power switch, located inside the heater on the bottom left corner.
      Ask FixBot
    3. Insignia NS-HTMC01-B Power Button Replacement: step 3, image 1 of 1
      • Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
      Ask FixBot
    4. Insignia NS-HTMC01-B Power Button Replacement: step 4, image 1 of 2 Insignia NS-HTMC01-B Power Button Replacement: step 4, image 2 of 2
      • Find the clips holding the power button in place.
      • Press down on the clips to remove the button.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 391
