Insignia NS-HTMC01-B Fan Replacement
  1. Insignia NS-HTMC01-B Fan Replacement, Fan: step 1, image 1 of 1
    • Flip your device over so the back panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
    Ask FixBot
  2. Insignia NS-HTMC01-B Fan Replacement: step 2, image 1 of 1
    • Rotate the screwdriver counter-clockwise until screws are removed.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws impossible to remove.
    • Remove the back panel.
    Ask FixBot
  3. Insignia NS-HTMC01-B Fan Replacement: step 3, image 1 of 1
    • Unscrew the four 9 millimeter, sharp-point screws holding the fan in place.
    Ask FixBot
  4. Insignia NS-HTMC01-B Fan Replacement: step 4, image 1 of 2 Insignia NS-HTMC01-B Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to disconnect the red and black wires.
    • Remove the fan.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
But what is the fan size?
William McGroarty - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 636
