Insignia NS-HD01A Battery Replacement
  1. Insignia NS-HD01A Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the rubber screw caps using the pointed tip of the Spudger.
    Ask FixBot
  2. Insignia NS-HD01A Battery Replacement: step 2, image 1 of 1
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
    Ask FixBot
  3. Insignia NS-HD01A Battery Replacement: step 3, image 1 of 2 Insignia NS-HD01A Battery Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
    Ask FixBot
  4. Insignia NS-HD01A Battery Replacement: step 4, image 1 of 3 Insignia NS-HD01A Battery Replacement: step 4, image 2 of 3 Insignia NS-HD01A Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
    Ask FixBot
  5. Insignia NS-HD01A Battery Replacement: step 5, image 1 of 2 Insignia NS-HD01A Battery Replacement: step 5, image 2 of 2
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
    Ask FixBot
2 other people completed this guide.
Joel Najmon
152 Reputation
1 Guide authored
IUPUI, Team 2-2, Wilson Fall 2016 Member of IUPUI, Team 2-2, Wilson Fall 2016
IUPUI-WILSON-F16S2G2
5 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 1,644
