Insignia NS-CLOPP2 Antenna Replacement
  1. Insignia NS-CLOPP2 Antenna Replacement, Batteries: step 1, image 1 of 1
    • Flip the clock over to expose the battery cover shown in the top left corner.
    Ask FixBot
  2. Insignia NS-CLOPP2 Antenna Replacement: step 2, image 1 of 1
    • Remove the battery cover by gripping the grooves with your thumb and sliding the cover in the direction the arrow is pointing.
    Ask FixBot
  3. Insignia NS-CLOPP2 Antenna Replacement: step 3, image 1 of 1
    • Carefully push the battery towards the spring, creating a space to grab the battery and pull it out. Safely discard the old batteries.
    • Insert new batteries by matching the (+) and (-) symbols on the battery with the corresponding symbols on the device battery cavity. Push each battery in by pressing towards the spring and snapping into place on the opposite end.
    Ask FixBot
  4. Insignia NS-CLOPP2 Antenna Replacement, Screen: step 4, image 1 of 1
    • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
    Ask FixBot
  5. Insignia NS-CLOPP2 Antenna Replacement: step 5, image 1 of 1
    • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
    Ask FixBot
  6. Insignia NS-CLOPP2 Antenna Replacement: step 6, image 1 of 1
    • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
    Ask FixBot
  7. Insignia NS-CLOPP2 Antenna Replacement: step 7, image 1 of 1
    • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
    • To reassemble your device, follow these instructions in reverse order.
    Ask FixBot
  8. Insignia NS-CLOPP2 Antenna Replacement, Motherboard: step 8, image 1 of 1
    • First, remove the front screen. (See prerequisite screen removal guide.)
    Ask FixBot
  9. Insignia NS-CLOPP2 Antenna Replacement: step 9, image 1 of 1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
    Ask FixBot
  10. Insignia NS-CLOPP2 Antenna Replacement: step 10, image 1 of 1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
    Ask FixBot
  11. Insignia NS-CLOPP2 Antenna Replacement: step 11, image 1 of 1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    Ask FixBot
  12. Insignia NS-CLOPP2 Antenna Replacement, Antenna: step 12, image 1 of 1
    • Follow steps on removing the motherboard as a prerequisite.
    • Gently move the motherboard back, revealing the thin black wire that is the antenna. The antenna wire is, on the outside, located on the lower, middle back. Follow the wire from the outside to the inside to make sure it's the correct one.
    Ask FixBot
  13. Insignia NS-CLOPP2 Antenna Replacement: step 13, image 1 of 1
    • Pull the wire up, making sure it's connected to the motherboard from the back side. To replace the wire, cut it completely from the motherboard.
    Ask FixBot
  14. Insignia NS-CLOPP2 Antenna Replacement: step 14, image 1 of 1
    • To re-attach the antenna cord to the motherboard, use a soldering tool to connect the wire to the same spot it was originally attached to.
    Ask FixBot
  15. Insignia NS-CLOPP2 Antenna Replacement: step 15, image 1 of 1
    • Make sure the wire is securely in place in the correct area of the clock, labeled "antenna" from the outside.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Dilini De Silva
769 Reputation
5 Guides authored
Marist, Team 1-1, Laflen Spring 2015 Member of Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 412
