Insignia NS-CLIP02 Motherboard Replacement
  1. Insignia NS-CLIP02 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Set the clock radio on the work space so the bottom of the device is showing.
    Ask FixBot
  2. Insignia NS-CLIP02 Motherboard Replacement: step 2, image 1 of 2 Insignia NS-CLIP02 Motherboard Replacement: step 2, image 2 of 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
    Ask FixBot
  3. Insignia NS-CLIP02 Motherboard Replacement: step 3, image 1 of 2 Insignia NS-CLIP02 Motherboard Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
    Ask FixBot
  4. Insignia NS-CLIP02 Motherboard Replacement: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
    Ask FixBot
  5. Insignia NS-CLIP02 Motherboard Replacement: step 5, image 1 of 1
    • Remove the bottom cover from the device to reveal the motherboard.
    Ask FixBot
  6. Insignia NS-CLIP02 Motherboard Replacement: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
    Ask FixBot
  7. Insignia NS-CLIP02 Motherboard Replacement: step 7, image 1 of 1
    • Lift the motherboard away from the device.
    Ask FixBot
  8. Insignia NS-CLIP02 Motherboard Replacement: step 8, image 1 of 3 Insignia NS-CLIP02 Motherboard Replacement: step 8, image 2 of 3 Insignia NS-CLIP02 Motherboard Replacement: step 8, image 3 of 3
    • Disconnect the four cables connecting the motherboard to the device.
    Ask FixBot
Erik
405 Reputation
4 Guides authored
USF Tampa, Team 9-3, Leahy Winter 2015 Member of USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 373
