Up to 20% off select tools
Insignia NS-CLIP02 Keypad Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
679
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
If your Insignia NS-CLIP02 has a keypad that does not work, use this guide to replace the motherboard inside. Faulty motherboards cause the keypad to malfunction, so replacing it should cause the keypad to work again.
Physically unplug and switch off the device before you start. Once you have finished the replacement, consider recycling the old motherboard at an electronic recycling center near you.
    1. Insignia NS-CLIP02 Keypad Replacement, Keypad: step 1, image 1 of 1
      • Locate the bottom of the device.
      Ask FixBot
    2. Insignia NS-CLIP02 Keypad Replacement: step 2, image 1 of 1
      • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
      Ask FixBot
    3. Insignia NS-CLIP02 Keypad Replacement: step 3, image 1 of 1
      • Locate the 11mm screw beneath the sticker.
      Ask FixBot
    4. Insignia NS-CLIP02 Keypad Replacement: step 4, image 1 of 1
      • Using a plastic spudger, peel off the adhesive gel stoppers.
      Ask FixBot
    5. Insignia NS-CLIP02 Keypad Replacement: step 5, image 1 of 1
      • Continue peeling the rest of the gel stoppers from the bottom of the device.
      Ask FixBot
    6. Insignia NS-CLIP02 Keypad Replacement: step 6, image 1 of 1
      • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
      Ask FixBot
    7. Insignia NS-CLIP02 Keypad Replacement: step 7, image 1 of 1
      • Once you peel off the bottom from the device, you will see the motherboard.
      Ask FixBot
    8. Insignia NS-CLIP02 Keypad Replacement: step 8, image 1 of 1
      • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
      Ask FixBot
    9. Insignia NS-CLIP02 Keypad Replacement: step 9, image 1 of 1
      • Lift the motherboard from the device.
      Ask FixBot
    10. Insignia NS-CLIP02 Keypad Replacement: step 10, image 1 of 1
      • Locate the four plugs connecting the motherboard to the rest of the device.
      Ask FixBot
    11. Insignia NS-CLIP02 Keypad Replacement: step 11, image 1 of 1
      • Begin with removing the plug to your left.
      Ask FixBot
    12. Insignia NS-CLIP02 Keypad Replacement: step 12, image 1 of 1
      • Remove the plug to your right from the motherboard.
      Ask FixBot
    13. Insignia NS-CLIP02 Keypad Replacement: step 13, image 1 of 1
      • Remove the plug in the front of the lcd screen plug.
      Ask FixBot
    14. Insignia NS-CLIP02 Keypad Replacement: step 14, image 1 of 1
      • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the keypad.
      Ask FixBot
Author
with
Erik
405 Reputation
4 Guides authored
USF Tampa, Team 9-3, Leahy Winter 2015 Member of USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 679
