Insignia NS-CLIP02 30-Pin Connector Replacement
    1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: step 1, image 1 of 1
      • Locate the bottom of the device.
      Ask FixBot
    2. Insignia NS-CLIP02 30-Pin Connector Replacement: step 2, image 1 of 1
      • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
      Ask FixBot
    3. Insignia NS-CLIP02 30-Pin Connector Replacement: step 3, image 1 of 1
      • Locate the 11mm screw beneath the sticker.
      Ask FixBot
    4. Insignia NS-CLIP02 30-Pin Connector Replacement: step 4, image 1 of 1
      • Using the Plastic Spudger, peel off the adhesive gel stoppers.
      Ask FixBot
    5. Insignia NS-CLIP02 30-Pin Connector Replacement: step 5, image 1 of 1
      • Continue peeling the rest of the gel stoppers from the bottom of the device.
      Ask FixBot
    6. Insignia NS-CLIP02 30-Pin Connector Replacement: step 6, image 1 of 1
      • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
      Ask FixBot
    7. Insignia NS-CLIP02 30-Pin Connector Replacement: step 7, image 1 of 1
      • Once you peel off the bottom from the device, you will see the motherboard.
      Ask FixBot
    8. Insignia NS-CLIP02 30-Pin Connector Replacement: step 8, image 1 of 1
      • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
      Ask FixBot
    9. Insignia NS-CLIP02 30-Pin Connector Replacement: step 9, image 1 of 1
      • Lift the motherboard from the device.
      Ask FixBot
    10. Insignia NS-CLIP02 30-Pin Connector Replacement: step 10, image 1 of 1
      • Locate the four plugs connecting the motherboard to the rest of the device.
      Ask FixBot
    11. Insignia NS-CLIP02 30-Pin Connector Replacement: step 11, image 1 of 1
      • Begin with removing the plug to your left.
      Ask FixBot
    12. Insignia NS-CLIP02 30-Pin Connector Replacement: step 12, image 1 of 1
      • Remove the plug to your right from the motherboard.
      Ask FixBot
    13. Insignia NS-CLIP02 30-Pin Connector Replacement: step 13, image 1 of 1
      • Remove the plug in front of the LCD screen plug.
      Ask FixBot
    14. Insignia NS-CLIP02 30-Pin Connector Replacement: step 14, image 1 of 1
      • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
      Ask FixBot
Erik
405 Reputation
4 Guides authored
USF Tampa, Team 9-3, Leahy Winter 2015 Member of USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 508
