Insignia NS-BCDCAS1 CD Laser Lens Replacement
  1. Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: step 1, image 1 of 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: step 1, image 2 of 2
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
    Ask FixBot
  2. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 2, image 1 of 1
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
    Ask FixBot
  3. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 3, image 1 of 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 3, image 2 of 2
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
    Ask FixBot
  4. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 4, image 1 of 1
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
    Ask FixBot
  5. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 5, image 1 of 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 5, image 2 of 2
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
    Ask FixBot
  6. Insignia NS-BCDCAS1 CD Laser Lens Replacement, CD Laser Lens: step 6, image 1 of 1
    • Unplug the red and black wires from the large yellow motherboard by pulling upwards.
    Ask FixBot
  7. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 7, image 1 of 1
    • Unplug the thick, white and pink cord from underneath the black top by pulling downwards.
    Ask FixBot
  8. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 8, image 1 of 1
    • Remove the black shiny strip from both ends of the white motherboard adaptor.
    Ask FixBot
  9. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 9, image 1 of 1
    • Using a Phillips #0, remove the two 11mm screws attached to the green legs underneath the top panel.
    Ask FixBot
  10. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 10, image 1 of 1
    • With a plastic opening tool, take off the red rings on the other two green legs.
    • The red rings fall off easily once loosened.
    Ask FixBot
  11. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 11, image 1 of 1
    • Using a JIS 1, remove the 8mm screw on the grey, square plate.
    Ask FixBot
  12. Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 12, image 1 of 3 Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 12, image 2 of 3 Insignia NS-BCDCAS1 CD Laser Lens Replacement: step 12, image 3 of 3
    • Slide the silver bar out.
    • Everything will be loosened. Support it with your hand
    • The square cube with the tiny lense is loosened. Slide it down to take out of the nook.
    • Detach the black tape so the cube is completely by itself. Replace the cube with a new one.
    Ask FixBot
2 other people completed this guide.
Erin King
215 Reputation
2 Guides authored
CSU Fullerton, Team 2-5, Bruce Fall 2016 Member of CSU Fullerton, Team 2-5, Bruce Fall 2016
CSUF-BRUCE-F16S2G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 1,563
