Insignia NS-B2110 Transformer Replacement
  1. Insignia NS-B2110 Transformer Replacement, Battery: step 1, image 1 of 2 Insignia NS-B2110 Transformer Replacement, Battery: step 1, image 2 of 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
    Ask FixBot
  2. Insignia NS-B2110 Transformer Replacement: step 2, image 1 of 2 Insignia NS-B2110 Transformer Replacement: step 2, image 2 of 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
    Ask FixBot
  3. Insignia NS-B2110 Transformer Replacement, Bottom Panel: step 3, image 1 of 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
    Ask FixBot
  4. Insignia NS-B2110 Transformer Replacement: step 4, image 1 of 2 Insignia NS-B2110 Transformer Replacement: step 4, image 2 of 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
    Ask FixBot
  5. Insignia NS-B2110 Transformer Replacement: step 5, image 1 of 3 Insignia NS-B2110 Transformer Replacement: step 5, image 2 of 3 Insignia NS-B2110 Transformer Replacement: step 5, image 3 of 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
    Ask FixBot
  6. Insignia NS-B2110 Transformer Replacement, Transformer: step 6, image 1 of 2 Insignia NS-B2110 Transformer Replacement, Transformer: step 6, image 2 of 2
    • Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
    • Remove the transformer and set it to the side.
    Ask FixBot
  7. Insignia NS-B2110 Transformer Replacement: step 7, image 1 of 1
    • Remove the solder connecting the two yellow wires to the green quarter-circle board.
    Ask FixBot
  8. Insignia NS-B2110 Transformer Replacement: step 8, image 1 of 3 Insignia NS-B2110 Transformer Replacement: step 8, image 2 of 3 Insignia NS-B2110 Transformer Replacement: step 8, image 3 of 3
    • There will be a strip of electrical tape securing the converter. Use scissors to carefully remove this tape.
    • Use a Phillips #2 screwdriver to remove two 4mm screws from the converter.
    • Remove the converter. There will be a plastic casing that slides off; set this aside.
    Ask FixBot
  9. Insignia NS-B2110 Transformer Replacement: step 9, image 1 of 1
    • Remover the solder from the red and yellow wires on the converter.
    Ask FixBot
Jacob Phillips
313 Reputation
3 Guides authored
Cal Poly, Team 4-31, Amido Fall 2013 Member of Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 596
