Introduction
Go to step 1 ↓If the buttons on the stereo's face or the visual display are not working, you may need to remove them from the device to be replaced. This guide shows how to go about removing the buttons and LED display. This guide requires a knowledge of soldering. If you don't know how, follow this very simple step-by-step soldering guide
Tools
Spudger4.9
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
Remove the green quarter circle circuit board and place to the side.
Remove the black plastic tuner assembly piece using the blue plastic opening tool.
To reassemble your device, follow these instructions in reverse order. Solder the wires back on where they have been soldered off.
