Insignia NS-15MS0832B Battery Replacement
    1. Insignia NS-15MS0832B Battery  Replacement, Battery: step 1, image 1 of 1
      • Begin the replacement for the battery by opening up the device with a plastic opening tool along the edge.
      • Work the plastic opening tool along the edge until you have separated the screen from the back plate.
      Ask FixBot
    2. Insignia NS-15MS0832B Battery  Replacement: step 2, image 1 of 1
      • Your tablet should look like this once separated.
      Ask FixBot
    3. Insignia NS-15MS0832B Battery  Replacement: step 3, image 1 of 1
      • Start by placing tablet face down and carefully removing the mesh wire tap from the back of the battery.
      Ask FixBot
    4. Insignia NS-15MS0832B Battery  Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the flat wire from its connector with the tweezers and fold to the side so that it's clear of the battery.
      Ask FixBot
    5. Insignia NS-15MS0832B Battery  Replacement: step 5, image 1 of 1
      • Next locate where the battery has three wires attached to the mother board. Take out the soldering iron and begin heating it up.
      • Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
      Ask FixBot
    6. Insignia NS-15MS0832B Battery  Replacement: step 6, image 1 of 1
      • Once the soldering iron has heated up, begin by placing the tip of the iron where the wire directly meets the mother board. The soldering should heat up and allow you to gently pull the wire off. Repeat twice more to remove each of the three wires.
      Ask FixBot
    7. Insignia NS-15MS0832B Battery  Replacement: step 7, image 1 of 1
      • Once all wires have been removed from mother board, take plastic opening tool and separate the battery from the back of the screen. Its connected with glue, so don't worry.
      Ask FixBot
    8. Insignia NS-15MS0832B Battery  Replacement: step 8, image 1 of 1
      • Remove battery and replace faulty one with new battery.
      Ask FixBot
To reassemble your Insignia W-Fi Windows 8" Tablet, follow these instructions in reverse order.
Harrison Smith
329 Reputation
3 Guides authored
Texas Tech, Team 1-1, Bennett Fall 2016 Member of Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,518
