Up to 20% off select tools
Insignia Flex 8 Screen Replacement
Views: 9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
81
All Time:
8,966
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This process is simple once the tablet is disassembled and requires only requires a prying tool.
    1. Insignia Flex 8 Screen Replacement, Circuit Board: step 1, image 1 of 1
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      Ask FixBot
    2. Insignia Flex 8 Screen Replacement: step 2, image 1 of 2 Insignia Flex 8 Screen Replacement: step 2, image 2 of 2
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      Ask FixBot
    3. Insignia Flex 8 Screen Replacement: step 3, image 1 of 2 Insignia Flex 8 Screen Replacement: step 3, image 2 of 2
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      Ask FixBot
    4. Insignia Flex 8 Screen Replacement: step 4, image 1 of 3 Insignia Flex 8 Screen Replacement: step 4, image 2 of 3 Insignia Flex 8 Screen Replacement: step 4, image 3 of 3
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      Ask FixBot
    5. Insignia Flex 8 Screen Replacement: step 5, image 1 of 3 Insignia Flex 8 Screen Replacement: step 5, image 2 of 3 Insignia Flex 8 Screen Replacement: step 5, image 3 of 3
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      Ask FixBot
    6. Insignia Flex 8 Screen Replacement: step 6, image 1 of 3 Insignia Flex 8 Screen Replacement: step 6, image 2 of 3 Insignia Flex 8 Screen Replacement: step 6, image 3 of 3
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      Ask FixBot
    7. Insignia Flex 8 Screen Replacement: step 7, image 1 of 2 Insignia Flex 8 Screen Replacement: step 7, image 2 of 2
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      Ask FixBot
    8. Insignia Flex 8 Screen Replacement: step 8, image 1 of 2 Insignia Flex 8 Screen Replacement: step 8, image 2 of 2
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      Ask FixBot
    9. Insignia Flex 8 Screen Replacement: step 9, image 1 of 1
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      Ask FixBot
    10. Insignia Flex 8 Screen Replacement: step 10, image 1 of 1
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      Ask FixBot
    1. Insignia Flex 8 Screen Replacement, Screen: step 11, image 1 of 1
      • Slide the spudger in between the silver screen and the black border
      Ask FixBot
    2. Insignia Flex 8 Screen Replacement: step 12, image 1 of 1
      • Pry up the LCD display and lift it away from the plastic screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Tyler Tyrrell
890 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 81
All Time: 8,966
