Insignia Flex 7 Battery Replacement
    1. Insignia Flex 7 Battery Replacement, Battery: step 1, image 1 of 3 Insignia Flex 7 Battery Replacement, Battery: step 1, image 2 of 3 Insignia Flex 7 Battery Replacement, Battery: step 1, image 3 of 3
      • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
      • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
      Ask FixBot
    2. Insignia Flex 7 Battery Replacement: step 2, image 1 of 2 Insignia Flex 7 Battery Replacement: step 2, image 2 of 2
      • Place the tip of the spudger on each side of the battery's electrical connector.
      • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
      Ask FixBot
    3. Insignia Flex 7 Battery Replacement: step 3, image 1 of 3 Insignia Flex 7 Battery Replacement: step 3, image 2 of 3 Insignia Flex 7 Battery Replacement: step 3, image 3 of 3
      • Insert the flat end of the spudger under one side of the battery.
      • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
      • Repeat the process for the other side of the battery.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Link for replacement battery?
Mike - Reply Share
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,263
