Insignia Flex 11.6 Screen Replacement
  1. Insignia Flex 11.6 Screen Replacement, Power Removal: step 1, image 1 of 3 Insignia Flex 11.6 Screen Replacement, Power Removal: step 1, image 2 of 3 Insignia Flex 11.6 Screen Replacement, Power Removal: step 1, image 3 of 3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Screen Replacement: step 2, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 2, image 2 of 2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Screen Replacement: step 3, image 1 of 3 Insignia Flex 11.6 Screen Replacement: step 3, image 2 of 3 Insignia Flex 11.6 Screen Replacement: step 3, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Screen Replacement: step 4, image 1 of 3 Insignia Flex 11.6 Screen Replacement: step 4, image 2 of 3 Insignia Flex 11.6 Screen Replacement: step 4, image 3 of 3
    Buy
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Screen Replacement, Motherboard: step 5, image 1 of 1
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Screen Replacement: step 6, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 6, image 2 of 2
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Screen Replacement: step 7, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 7, image 2 of 2
    Buy
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Screen Replacement: step 8, image 1 of 3 Insignia Flex 11.6 Screen Replacement: step 8, image 2 of 3 Insignia Flex 11.6 Screen Replacement: step 8, image 3 of 3
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Screen Replacement: step 9, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 9, image 2 of 2
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Screen Replacement: step 10, image 1 of 1
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
  11. Insignia Flex 11.6 Screen Replacement, Screen: step 11, image 1 of 3 Insignia Flex 11.6 Screen Replacement, Screen: step 11, image 2 of 3 Insignia Flex 11.6 Screen Replacement, Screen: step 11, image 3 of 3
    • Remove battery by prying off with card.
  12. Insignia Flex 11.6 Screen Replacement: step 12, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 12, image 2 of 2
    • Peel back the copper color electrical connector with blue opening tool.
  13. Insignia Flex 11.6 Screen Replacement: step 13, image 1 of 1
    • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
    • Bracket will then come off.
  14. Insignia Flex 11.6 Screen Replacement: step 14, image 1 of 1
    • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  15. Insignia Flex 11.6 Screen Replacement: step 15, image 1 of 2 Insignia Flex 11.6 Screen Replacement: step 15, image 2 of 2
    • Remove screen from case by prying with a card.
4 other people completed this guide.
6 Guide Comments
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - Reply Share
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis - Share
mine doesn’t look like that…
Joshua Francis - Reply Share
where can i get a new screen to buy?
florence sefaa - Reply Share
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 4,961
