Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: step 1, image 1 of 1
    • Remove the lid and place it upside-down on a flat surface.
    Ask FixBot
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: step 2, image 1 of 1
    • Pinch the rubber gasket on the float valve and pull up.
    Ask FixBot
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: step 3, image 1 of 2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: step 3, image 2 of 2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
    Ask FixBot
3 other people completed this guide.
Savannah Webb
657 Reputation
5 Guides authored
Cal Poly, Team S12-G3, Banghart Winter 2018 Member of Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Members
7 Guides authored
4 Guide Comments
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Reply Share
It happened to me as well. Right after I replaced it, it doesn’t hold the pressure. I am very annoyed and I wish I have kept the old parts!!!!
Valentina - Reply Share
OK after much digging, I found the old valve and now it is pressurizing.
where can I buy the float valves
valuacion.urbanismo - Reply Share
Past 24 Hours: 3
Past 7 Days: 40
Past 30 Days: 173
All Time: 7,062
