Inse N500 Motor Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
103
All Time:
1,962
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Inse vacuum (model N500) is producing strange noises due to dust and debris in the motorhead, use this repair guide for the motor replacement.
Tools
    1. Inse N500 Motor Replacement, Dustbin: step 1, image 1 of 3 Inse N500 Motor Replacement, Dustbin: step 1, image 2 of 3 Inse N500 Motor Replacement, Dustbin: step 1, image 3 of 3
      • Unclip the plastic band from the vacuum head.
      Ask FixBot
    2. Inse N500 Motor Replacement: step 2, image 1 of 2 Inse N500 Motor Replacement: step 2, image 2 of 2
      • Remove six 6 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. Inse N500 Motor Replacement: step 3, image 1 of 2 Inse N500 Motor Replacement: step 3, image 2 of 2
      • Remove the vacuum head guard.
      Ask FixBot
    4. Inse N500 Motor Replacement: step 4, image 1 of 2 Inse N500 Motor Replacement: step 4, image 2 of 2
      • Remove the ten 4 mm screws using a Phillips #0 screwdriver.
      • There are five screws on each side of the vacuum.
      Ask FixBot
    5. Inse N500 Motor Replacement: step 5, image 1 of 2 Inse N500 Motor Replacement: step 5, image 2 of 2
      • Remove the single 4 mm screw from the circuit board using a Phillips #0 screwdriver.
      Ask FixBot
    6. Inse N500 Motor Replacement: step 6, image 1 of 2 Inse N500 Motor Replacement: step 6, image 2 of 2
      • Unfasten the remaining clips.
      Ask FixBot
    7. Inse N500 Motor Replacement: step 7, image 1 of 3 Inse N500 Motor Replacement: step 7, image 2 of 3 Inse N500 Motor Replacement: step 7, image 3 of 3
      • Remove the dustbin.
      Ask FixBot
    1. Inse N500 Motor Replacement, Motor: step 8, image 1 of 2 Inse N500 Motor Replacement, Motor: step 8, image 2 of 2
      • Unfasten the surrounding motor clips and remove the motor.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Please 🙏 the motor of roborock h7 please 🙏
Wayl - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 103
All Time: 1,962
