Innioasis Y1 SD Card Replacement
    1. Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 1 of 3 Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 2 of 3 Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 3 of 3
      • Use a pry tool and start half way up the left or right side of the MP3 player, working your way around the edge
      • Carefully lift the cover off and detach the connecting cable
      Ask FixBot
    1. Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 1 of 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 2 of 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 3 of 3
      • Remove the 3 screws with a Philips #00
      • Carefully remove the Speaker from its clasps with a pry tool
      • Carefully lift the board on the left side with the pry tool
      Ask FixBot
    2. Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 1 of 3 Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 2 of 3 Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 3 of 3
      • Carefully Lift the board up and towards the screen. You may need to lightly pry the battery out of its socket
      • Remove the tape
      • Slide the Micro SD card out of the socket
      Ask FixBot
16 other people completed this guide.
Dan
5,252 Reputation
9 Guides authored
20 Guide Comments
Tired of waiting for a reaction to my questions above I bought a Samsung 512GB Micro SD Evo Plus UHS-I U3 SDcard. Maybe overkill, but very fast. the replacement of the card was a 5 minutes job. Now I am copying the contents of the old 128GB card to the Innioasis Y3 which will take hours I guess. I let everyone know if it all works fine.
P. Reuvers - Reply Share
It works great. Only one small issue. The Innioasis Y1 shows that it contain 128GB, But he shows the correct used and available space, at this moment I used 143GB of the 512GB, more then the original Innioasis Y1.
Any suggestion on how to format the SD Card? thanks
Paninaro - Reply Share
Will this work with an ExFAT format card or just FAT32? Thanks
jjedwards894 - Reply Share
ExFAT worked fine for me.
Tanner Mills - Reply Share
Past 24 Hours: 45
Past 7 Days: 258
Past 30 Days: 1,103
All Time: 41,182
