Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓If the monitor screen isn’t properly displaying images or camera feed from the Infant Optics DXR-8 cameras, it may be time to replace the screen. Follow these instructions to replace the screen in the monitor of the Infant Optics DXR-8.
Tools
Using the plastic opening tool, remove screen protector from front of monitor.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
2 other people completed this guide.
7 Guide Comments
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
Does this improve the brightness of the screen or is it essentially an OEM replacement? I have found the monitor to be basically unusable in daylight conditions (like every midday nap) so I’m hoping to add some anti glare and boost the screen brightness/contrast.
Thanks for the information!
Excellent guide! Followed the step by step here and it went super smooth, new screen installed with no issues whatsoever!!
Thanks Daniel for putting it up and other authors for tweaking!
I hadn’t seen this website yet, but I’m glad I found it now!! This is awesome!!
