Infant Optics DXR-8 Monitor Motherboard Replacement
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: step 1, image 1 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: step 1, image 2 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: step 1, image 3 of 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
    Ask FixBot
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: step 2, image 1 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 2, image 2 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 2, image 3 of 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
    Ask FixBot
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: step 3, image 1 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 3, image 2 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 3, image 3 of 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Ask FixBot
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: step 4, image 1 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: step 4, image 2 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: step 4, image 3 of 3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
    Ask FixBot
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: step 5, image 1 of 2 Infant Optics DXR-8 Monitor Motherboard Replacement: step 5, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
    Ask FixBot
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: step 6, image 1 of 1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
    Ask FixBot
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: step 7, image 1 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 7, image 2 of 3 Infant Optics DXR-8 Monitor Motherboard Replacement: step 7, image 3 of 3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
    Ask FixBot
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: step 8, image 1 of 2 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: step 8, image 2 of 2
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
    Ask FixBot
2 Guide Comments
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - Reply Share
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 53
All Time: 2,056
