Infant Optics DXR-8 Antenna Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Infant Optics DXR-8 Antenna Replacement, Antenna: step 1, image 1 of 1
      • At the top right, the insulated wire exposes the antenna.
      Ask FixBot
    2. Infant Optics DXR-8 Antenna Replacement: step 2, image 1 of 2 Infant Optics DXR-8 Antenna Replacement: step 2, image 2 of 2
      • Locate antenna connection.
      • Desolder wire to remove. An antenna of a new length can be soldered to the board for improved signal strength.
      • Be careful when using soldering iron.
      Ask FixBot
Larsha Johnson
538 Reputation
3 Guides authored
USF Tampa, Team 6-4, Remmell Fall 2015 Member of USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 Members
36 Guides authored
2 Guide Comments
That’s fine but what antenna did you purchase? My antennae wire is actually broken, started out with the plastic piece breaking then the cable snapped.
Henry Scharf - Reply Share
I would also like to know what replacement antenna you used.
stilesmccauley - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 6,938
