Infant Optics DXR-5 Mother Board Replacement
  1. Infant Optics DXR-5 Mother Board Replacement, Battery: step 1, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement, Battery: step 1, image 2 of 2
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
    Ask FixBot
  2. Infant Optics DXR-5 Mother Board Replacement: step 2, image 1 of 1
    • Pull the blue clip away from the body of the hand held monitor.
    Ask FixBot
  3. Infant Optics DXR-5 Mother Board Replacement: step 3, image 1 of 1
    • Slide the rear white panel off as shown.
    Ask FixBot
  4. Infant Optics DXR-5 Mother Board Replacement: step 4, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 4, image 2 of 2
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
    Ask FixBot
  5. Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: step 5, image 1 of 3 Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: step 5, image 2 of 3 Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: step 5, image 3 of 3
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
    Ask FixBot
  6. Infant Optics DXR-5 Mother Board Replacement: step 6, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 6, image 2 of 2
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
    Ask FixBot
  7. Infant Optics DXR-5 Mother Board Replacement: step 7, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 7, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
    Ask FixBot
  8. Infant Optics DXR-5 Mother Board Replacement: step 8, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 8, image 2 of 2
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
    Ask FixBot
  9. Infant Optics DXR-5 Mother Board Replacement: step 9, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 9, image 2 of 2
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
    Ask FixBot
  10. Infant Optics DXR-5 Mother Board Replacement: step 10, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 10, image 2 of 2
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
    Ask FixBot
  11. Infant Optics DXR-5 Mother Board Replacement, Mother Board: step 11, image 1 of 1
    • Using a soldering iron remove the leads from the speaker on the front plate of the hand held monitor.
    • The leads must be put back in the correct order.
    Ask FixBot
  12. Infant Optics DXR-5 Mother Board Replacement: step 12, image 1 of 2 Infant Optics DXR-5 Mother Board Replacement: step 12, image 2 of 2
    • Remove the adhesive around the antenna wire.
    • Remove the antenna wire from the back plate of the hand held monitor.
    Ask FixBot
3 other people completed this guide.
Charles Neal
687 Reputation
5 Guides authored
USF Tampa, Team 6-2, Remmell Fall 2015 Member of USF Tampa, Team 6-2, Remmell Fall 2015
USFT-REMMELL-F15S6G2
5 Members
5 Guides authored
1 Guide Comment
Great pictures! They enabled me to find the two hidden screws. I removed them (and the other obvious screws) and then bent charging pin back to intended position. The monitor is now charging again! Thanks!!
michael_a_hahn - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 1,817
