India Mark III Axle and Handle Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
85
All Time:
881
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to remove the axle and the handle from the India Mark III. You can then replace or repair either component.
    1. India Mark III Axle and Handle Replacement, Access Door: step 1, image 1 of 2 India Mark III Axle and Handle Replacement, Access Door: step 1, image 2 of 2
      • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
      • Remove the hex head bolt from the top of the access door on the pump head.
      • On reassembly, this bolt should be hand-tight.
      Ask FixBot
    2. India Mark III Axle and Handle Replacement: step 2, image 1 of 3 India Mark III Axle and Handle Replacement: step 2, image 2 of 3 India Mark III Axle and Handle Replacement: step 2, image 3 of 3
      • Pull the access door straight up off the pump head.
      • Store the access door in a sanitary place to prevent contamination.
      Ask FixBot
    3. India Mark III Axle and Handle Replacement: step 3, image 1 of 2 India Mark III Axle and Handle Replacement: step 3, image 2 of 2
      • The access door has a tongue that fits into the base of the pump head.
      • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
      Ask FixBot
    1. India Mark III Axle and Handle Replacement, Chain: step 4, image 1 of 3 India Mark III Axle and Handle Replacement, Chain: step 4, image 2 of 3 India Mark III Axle and Handle Replacement, Chain: step 4, image 3 of 3
      • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
      Ask FixBot
    2. India Mark III Axle and Handle Replacement: step 5, image 1 of 3 India Mark III Axle and Handle Replacement: step 5, image 2 of 3 India Mark III Axle and Handle Replacement: step 5, image 3 of 3
      • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
      • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
      Ask FixBot
    3. India Mark III Axle and Handle Replacement: step 6, image 1 of 3 India Mark III Axle and Handle Replacement: step 6, image 2 of 3 India Mark III Axle and Handle Replacement: step 6, image 3 of 3
      • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
      Ask FixBot
    4. India Mark III Axle and Handle Replacement: step 7, image 1 of 3 India Mark III Axle and Handle Replacement: step 7, image 2 of 3 India Mark III Axle and Handle Replacement: step 7, image 3 of 3
      • Hold the wrench on the bolt stationary.
      • Loosen the nut.
      Ask FixBot
    5. India Mark III Axle and Handle Replacement: step 8, image 1 of 3 India Mark III Axle and Handle Replacement: step 8, image 2 of 3 India Mark III Axle and Handle Replacement: step 8, image 3 of 3
      • Remove the nut from the chain bolt.
      Ask FixBot
    6. India Mark III Axle and Handle Replacement: step 9, image 1 of 2 India Mark III Axle and Handle Replacement: step 9, image 2 of 2
      • Remove the washer from the chain bolt.
      Ask FixBot
    7. India Mark III Axle and Handle Replacement: step 10, image 1 of 2 India Mark III Axle and Handle Replacement: step 10, image 2 of 2
      • Remove the chain bolt.
      Ask FixBot
    8. India Mark III Axle and Handle Replacement: step 11, image 1 of 3 India Mark III Axle and Handle Replacement: step 11, image 2 of 3 India Mark III Axle and Handle Replacement: step 11, image 3 of 3
      • Pull the top of the chain straight off of the pump handle.
      Ask FixBot
    1. India Mark III Axle and Handle Replacement, Axle and Handle: step 12, image 1 of 3 India Mark III Axle and Handle Replacement, Axle and Handle: step 12, image 2 of 3 India Mark III Axle and Handle Replacement, Axle and Handle: step 12, image 3 of 3
      • Use a wrench to loosen the nut on the end of the handle axle.
      • Remove the nut and washer from the end of the axle.
      Ask FixBot
    2. India Mark III Axle and Handle Replacement: step 13, image 1 of 2 India Mark III Axle and Handle Replacement: step 13, image 2 of 2
      • Set the axle punch over the exposed threaded section of the axle.
      Ask FixBot
    3. India Mark III Axle and Handle Replacement: step 14, image 1 of 3 India Mark III Axle and Handle Replacement: step 14, image 2 of 3 India Mark III Axle and Handle Replacement: step 14, image 3 of 3
      • The first person will use a hammer to gently tap on the axle punch, to push the axle through the handle bearings and out of the pump head.
      • At the same time, a second person will hold up the handle, supporting its weight, while twisting the axle with a wrench, to loosen it in the bearings and make it easier to dislodge.
      Ask FixBot
    4. India Mark III Axle and Handle Replacement: step 15, image 1 of 2 India Mark III Axle and Handle Replacement: step 15, image 2 of 2
      • Gently tap the axle punch to push the axle out of the pump head.
      Ask FixBot
    5. India Mark III Axle and Handle Replacement: step 16, image 1 of 3 India Mark III Axle and Handle Replacement: step 16, image 2 of 3 India Mark III Axle and Handle Replacement: step 16, image 3 of 3
      • Once the axle is loose, push it through the pump head.
      Ask FixBot
    6. India Mark III Axle and Handle Replacement: step 17, image 1 of 3 India Mark III Axle and Handle Replacement: step 17, image 2 of 3 India Mark III Axle and Handle Replacement: step 17, image 3 of 3
      • While supporting the pump handle, remove the axle.
      Ask FixBot
    7. India Mark III Axle and Handle Replacement: step 18, image 1 of 3 India Mark III Axle and Handle Replacement: step 18, image 2 of 3 India Mark III Axle and Handle Replacement: step 18, image 3 of 3
      • Slide the pump handle out of the pump head.
      Ask FixBot
    8. India Mark III Axle and Handle Replacement: step 19, image 1 of 1
      • At this point you can inspect the pump handle bearing for damage or excessive wear.
      Ask FixBot
    9. India Mark III Axle and Handle Replacement: step 20, image 1 of 2 India Mark III Axle and Handle Replacement: step 20, image 2 of 2
      • The following steps demonstrate reassembly.
      • After sliding the pump handle back into the pump head, line up the pump handle bearing with the holes in the side of the pump head.
      Ask FixBot
    10. India Mark III Axle and Handle Replacement: step 21, image 1 of 3 India Mark III Axle and Handle Replacement: step 21, image 2 of 3 India Mark III Axle and Handle Replacement: step 21, image 3 of 3
      • Insert the axle back into the pump head.
      • Be sure to support the weight of the handle and line up the holes in the sides of the pump head with the pump handle bearing.
      Ask FixBot
    11. India Mark III Axle and Handle Replacement: step 22, image 1 of 2 India Mark III Axle and Handle Replacement: step 22, image 2 of 2
      • Use a block of wood and hammer to gently tap the axle back into place.
      • Do not hit the axle directly with a hammer, as you may damage it.
      Ask FixBot
    12. India Mark III Axle and Handle Replacement: step 23, image 1 of 3 India Mark III Axle and Handle Replacement: step 23, image 2 of 3 India Mark III Axle and Handle Replacement: step 23, image 3 of 3
      • Replace the washer and nut on the axle.
      • Tighten the nut with a wrench.
      Ask FixBot
Andrew Optimus Goldheart
516,304 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
120 Members
72,955 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 85
All Time: 881
