India Mark II Riser Main (Tripod) Replacement
  1. India Mark II Riser Main (Tripod) Replacement, Access Door: step 1, image 1 of 2 India Mark II Riser Main (Tripod) Replacement, Access Door: step 1, image 2 of 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
    Ask FixBot
  2. India Mark II Riser Main (Tripod) Replacement: step 2, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 2, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 2, image 3 of 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
    Ask FixBot
  3. India Mark II Riser Main (Tripod) Replacement: step 3, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 3, image 2 of 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
    Ask FixBot
  4. India Mark II Riser Main (Tripod) Replacement, Chain: step 4, image 1 of 3 India Mark II Riser Main (Tripod) Replacement, Chain: step 4, image 2 of 3 India Mark II Riser Main (Tripod) Replacement, Chain: step 4, image 3 of 3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
    Ask FixBot
  5. India Mark II Riser Main (Tripod) Replacement: step 5, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 5, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 5, image 3 of 3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
    Ask FixBot
  6. India Mark II Riser Main (Tripod) Replacement: step 6, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 6, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 6, image 3 of 3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
    Ask FixBot
  7. India Mark II Riser Main (Tripod) Replacement: step 7, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 7, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 7, image 3 of 3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
    Ask FixBot
  8. India Mark II Riser Main (Tripod) Replacement: step 8, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 8, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 8, image 3 of 3
    • Remove the nut from the chain bolt.
    Ask FixBot
  9. India Mark II Riser Main (Tripod) Replacement: step 9, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 9, image 2 of 2
    • Remove the washer from the chain bolt.
    Ask FixBot
  10. India Mark II Riser Main (Tripod) Replacement: step 10, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 10, image 2 of 2
    • Remove the chain bolt.
    Ask FixBot
  11. India Mark II Riser Main (Tripod) Replacement: step 11, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 11, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 11, image 3 of 3
    • Pull the top of the chain straight off of the pump handle.
    Ask FixBot
  12. India Mark II Riser Main (Tripod) Replacement, Head: step 12, image 1 of 3 India Mark II Riser Main (Tripod) Replacement, Head: step 12, image 2 of 3 India Mark II Riser Main (Tripod) Replacement, Head: step 12, image 3 of 3
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
    Ask FixBot
  13. India Mark II Riser Main (Tripod) Replacement: step 13, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 13, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 13, image 3 of 3
    • Remove the two bolts and nuts from the handle side.
    Ask FixBot
  14. India Mark II Riser Main (Tripod) Replacement: step 14, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 14, image 2 of 2
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
    Ask FixBot
  15. India Mark II Riser Main (Tripod) Replacement: step 15, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 15, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 15, image 3 of 3
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
    Ask FixBot
  16. India Mark II Riser Main (Tripod) Replacement, Chain: step 16, image 1 of 2 India Mark II Riser Main (Tripod) Replacement, Chain: step 16, image 2 of 2
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
    Ask FixBot
  17. India Mark II Riser Main (Tripod) Replacement: step 17, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 17, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 17, image 3 of 3
    • Lift the head flange up about one foot above the tank.
    Ask FixBot
  18. India Mark II Riser Main (Tripod) Replacement: step 18, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 18, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 18, image 3 of 3
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
    Ask FixBot
  19. India Mark II Riser Main (Tripod) Replacement: step 19, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 19, image 2 of 2
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
    Ask FixBot
  20. India Mark II Riser Main (Tripod) Replacement: step 20, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 20, image 2 of 2
    • Lower the head flange.
    Ask FixBot
  21. India Mark II Riser Main (Tripod) Replacement: step 21, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 21, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 21, image 3 of 3
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
    Ask FixBot
  22. India Mark II Riser Main (Tripod) Replacement, Head Flange: step 22, image 1 of 3 India Mark II Riser Main (Tripod) Replacement, Head Flange: step 22, image 2 of 3 India Mark II Riser Main (Tripod) Replacement, Head Flange: step 22, image 3 of 3
    • Remove the chain support from around the pump rod.
    Ask FixBot
  23. India Mark II Riser Main (Tripod) Replacement: step 23, image 1 of 1
    • Remove the jam nut from the top of the pump rod.
    Ask FixBot
  24. India Mark II Riser Main (Tripod) Replacement: step 24, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 24, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 24, image 3 of 3
    • Remove the head flange.
    Ask FixBot
  25. India Mark II Riser Main (Tripod) Replacement: step 25, image 1 of 1
    • Screw the jam nut back onto the top of the pump rod.
    Ask FixBot
  26. India Mark II Riser Main (Tripod) Replacement, Tank: step 26, image 1 of 3 India Mark II Riser Main (Tripod) Replacement, Tank: step 26, image 2 of 3 India Mark II Riser Main (Tripod) Replacement, Tank: step 26, image 3 of 3
    • Screw a T-handle onto the top of the pump rod. Tighten the T-handle up against the jam nut.
    Ask FixBot
  27. India Mark II Riser Main (Tripod) Replacement: step 27, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 27, image 2 of 2
    • Loosen the rod vise.
    Ask FixBot
  28. India Mark II Riser Main (Tripod) Replacement: step 28, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 28, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 28, image 3 of 3
    • Remove the rod vise from the tank.
    Ask FixBot
  29. India Mark II Riser Main (Tripod) Replacement: step 29, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 29, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 29, image 3 of 3
    • Remove the four bolts connecting the tank to the top flange.
    • Use one wrench on the bolt and a second wrench on the nut beneath. Hold the bolt still and loosen the nut.
    Ask FixBot
  30. India Mark II Riser Main (Tripod) Replacement: step 30, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 30, image 2 of 2
    • Twist the tank 45 degrees in order to get a better grasp on it.
    Ask FixBot
  31. India Mark II Riser Main (Tripod) Replacement: step 31, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 31, image 2 of 2
    • Lift the tank straight up, about one foot.
    • The tank is attached to the riser main, and the two must be lifted as a unit. Be careful and get help, as this can be very heavy.
    Ask FixBot
  32. India Mark II Riser Main (Tripod) Replacement: step 32, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 32, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 32, image 3 of 3
    • Have a third person place the pipe vise around the riser main, on top of the top flange.
    • Tighten the pipe vise securely around the riser main.
    Ask FixBot
  33. India Mark II Riser Main (Tripod) Replacement: step 33, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 33, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 33, image 3 of 3
    • Secure the pipe vise to the top flange with two bolts and nuts to hold the pipe vise in place.
    Ask FixBot
  34. India Mark II Riser Main (Tripod) Replacement: step 34, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 34, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 34, image 3 of 3
    • Unscrew the tank from the riser main.
    Ask FixBot
  35. India Mark II Riser Main (Tripod) Replacement: step 35, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 35, image 2 of 2
    • Lift the tank up a few inches above the top of the riser main.
    Ask FixBot
  36. India Mark II Riser Main (Tripod) Replacement: step 36, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 36, image 2 of 2
    • Insert the rod vise between the riser main and the tank, around the pump rod.
    • Tighten the rod vise onto the pump rod.
    Ask FixBot
  37. India Mark II Riser Main (Tripod) Replacement: step 37, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 37, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 37, image 3 of 3
    • Unscrew the T-handle from the pump rod and remove it.
    • Keep the T-handle ready to reattach to the pump rod after the tank is removed.
    Ask FixBot
  38. India Mark II Riser Main (Tripod) Replacement: step 38, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 38, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 38, image 3 of 3
    • Remove the tank.
    Ask FixBot
  39. India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: step 39, image 1 of 2 India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: step 39, image 2 of 2
    • Place a coupling over the pump rod, on top of the rod vise.
    Ask FixBot
  40. India Mark II Riser Main (Tripod) Replacement: step 40, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 40, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 40, image 3 of 3
    • Reattach the T-handle to the top of the pump rod.
    Ask FixBot
  41. India Mark II Riser Main (Tripod) Replacement: step 41, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 41, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 41, image 3 of 3
    • Loosen and remove the rod vise from the pump rod.
    • The coupling will drop down onto the riser main.
    Ask FixBot
  42. India Mark II Riser Main (Tripod) Replacement: step 42, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 42, image 2 of 2
    • Screw the coupling onto the end of the riser main.
    • Use a pipe wrench to tighten the coupling onto the riser main.
    Ask FixBot
  43. India Mark II Riser Main (Tripod) Replacement, Riser Main: step 43, image 1 of 3 India Mark II Riser Main (Tripod) Replacement, Riser Main: step 43, image 2 of 3 India Mark II Riser Main (Tripod) Replacement, Riser Main: step 43, image 3 of 3
    • Lower the tripod pipe vise to the top of the riser main.
    • Close the tripod pipe vise around the riser main, and lock it shut.
    Ask FixBot
  44. India Mark II Riser Main (Tripod) Replacement: step 44, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 44, image 2 of 2
    • Tighten the tripod pipe vise.
    Ask FixBot
  45. India Mark II Riser Main (Tripod) Replacement: step 45, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 45, image 2 of 2
    • This procedure requires an important communication dialog between the rope operator and the pipe vise operator.
    • The rope operator's job is to pull hard on the rope to take up the slack, and announce that they've "got it," to let the vise operator know that they're holding the weight of the riser main.
    • The vise operator will then announce "loosening," and loosen the pipe vise.
    Ask FixBot
  46. India Mark II Riser Main (Tripod) Replacement: step 46, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 46, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 46, image 3 of 3
    • With the pipe vise loosened, pull the riser main up out of the well.
    • Pull only as high as the tripod vise operator can comfortably reach.
    Ask FixBot
  47. India Mark II Riser Main (Tripod) Replacement: step 47, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 47, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 47, image 3 of 3
    • The pipe vise operator then announces "tightening," and tightens the pipe vise.
    • It is now safe to loosen and remove the tripod pipe vise.
    • Be sure to loosen and then fully remove the tripod pipe vise from the riser main. Sliding it down the riser main will scratch the pipe, creating dangerous sharp grooves and causing rust.
    Ask FixBot
  48. India Mark II Riser Main (Tripod) Replacement: step 48, image 1 of 2 India Mark II Riser Main (Tripod) Replacement: step 48, image 2 of 2
    • Lower the tripod pipe vise down to the bottom of the exposed section of riser main pipe.
    Ask FixBot
  49. India Mark II Riser Main (Tripod) Replacement: step 49, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 49, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 49, image 3 of 3
    • Secure the tripod pipe vise to the riser main pipe and tighten it securely.
    Ask FixBot
  50. India Mark II Riser Main (Tripod) Replacement: step 50, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 50, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 50, image 3 of 3
    • Repeat the lifting procedure: loosen the pipe vise and pull on the rope to raise the riser main another few feet.
    Ask FixBot
  51. India Mark II Riser Main (Tripod) Replacement: step 51, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 51, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 51, image 3 of 3
    • The tripod has an indentation built into its top to guide the riser pipe.
    • As you're raising the riser pipe, guide it into the indentation.
    Ask FixBot
  52. India Mark II Riser Main (Tripod) Replacement: step 52, image 1 of 3 India Mark II Riser Main (Tripod) Replacement: step 52, image 2 of 3 India Mark II Riser Main (Tripod) Replacement: step 52, image 3 of 3
    • Lift the riser pipe until the first coupling clears the pipe vise.
    • You will need to open the pipe vise wider to accommodate the coupling.
    • Once the coupling is through the pipe vise, tighten the pipe vise.
    • Be sure to raise the riser main pipe high enough that you can attach the tripod pipe vise to the section of pipe beneath the coupling.
    Ask FixBot
    • From here we have pictures for loosening a coupling with the tripod?
    Ask FixBot
Andrew Optimus Goldheart
515,323 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 43
All Time: 1,053
