InFocus Screenplay 4805 Light Tunnel Replacement
    1. InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: step 1, image 1 of 3 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: step 1, image 2 of 3 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: step 1, image 3 of 3
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
      Ask FixBot
    2. InFocus Screenplay 4805 Light Tunnel Replacement: step 2, image 1 of 2 InFocus Screenplay 4805 Light Tunnel Replacement: step 2, image 2 of 2
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
      Ask FixBot
    3. InFocus Screenplay 4805 Light Tunnel Replacement: step 3, image 1 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 3, image 2 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 3, image 3 of 3
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
      Ask FixBot
    4. InFocus Screenplay 4805 Light Tunnel Replacement: step 4, image 1 of 1
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
      Ask FixBot
    5. InFocus Screenplay 4805 Light Tunnel Replacement: step 5, image 1 of 1
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
      Ask FixBot
    1. InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: step 6, image 1 of 3 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: step 6, image 2 of 3 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: step 6, image 3 of 3
      • With the lens facing you, remove the following screws:
      • Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
      • Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
      • Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
      Ask FixBot
    2. InFocus Screenplay 4805 Light Tunnel Replacement: step 7, image 1 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 7, image 2 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 7, image 3 of 3
      • Using a Phillips #0 screwdriver remove the three 1 cm black screws from the lens house.
      • Remove the lens unit.
      Ask FixBot
    3. InFocus Screenplay 4805 Light Tunnel Replacement: step 8, image 1 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 8, image 2 of 3 InFocus Screenplay 4805 Light Tunnel Replacement: step 8, image 3 of 3
      • Using the Phillips #0 head, unscrew the four 1 cm black screws.
      • Remove the metal casings holding the tunnel in place.
      Ask FixBot
    4. InFocus Screenplay 4805 Light Tunnel Replacement: step 9, image 1 of 2 InFocus Screenplay 4805 Light Tunnel Replacement: step 9, image 2 of 2
      • Using the Phillips #0 head, unscrew the black 0.5 cm screw on the bottom of the lens house.
      • Remove the light tunnel.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,184
