Up to 20% off select tools
InFocus Screenplay 4805 Lens Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
86
All Time:
1,224
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replace the lens if you are experiencing a lack of an image when the projector is on.
You will need a replacement lens as well as a clean, micro fabric cloth in case the replacement lens needs to be cleaned.
    1. InFocus Screenplay 4805 Lens Replacement, Top Panel: step 1, image 1 of 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: step 1, image 2 of 3 InFocus Screenplay 4805 Lens Replacement, Top Panel: step 1, image 3 of 3
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
      Ask FixBot
    2. InFocus Screenplay 4805 Lens Replacement: step 2, image 1 of 2 InFocus Screenplay 4805 Lens Replacement: step 2, image 2 of 2
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
      Ask FixBot
    3. InFocus Screenplay 4805 Lens Replacement: step 3, image 1 of 3 InFocus Screenplay 4805 Lens Replacement: step 3, image 2 of 3 InFocus Screenplay 4805 Lens Replacement: step 3, image 3 of 3
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
      Ask FixBot
    4. InFocus Screenplay 4805 Lens Replacement: step 4, image 1 of 1
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
      Ask FixBot
    5. InFocus Screenplay 4805 Lens Replacement: step 5, image 1 of 1
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
      Ask FixBot
    1. InFocus Screenplay 4805 Lens Replacement, Lens: step 6, image 1 of 3 InFocus Screenplay 4805 Lens Replacement, Lens: step 6, image 2 of 3 InFocus Screenplay 4805 Lens Replacement, Lens: step 6, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
      • Gently pull out the lens.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
Author
with
Marilyn Urness
671 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 86
All Time: 1,224
