Up to 20% off select tools
InFocus LP540 Projector Lens Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
3,349
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 1 of 3 InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 2 of 3 InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 3 of 3
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      Ask FixBot
    2. InFocus LP540 Projector Lens Replacement: step 2, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 2, image 2 of 2
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      Ask FixBot
    3. InFocus LP540 Projector Lens Replacement: step 3, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 3, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 3, image 3 of 3
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      Ask FixBot
    4. InFocus LP540 Projector Lens Replacement: step 4, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 4, image 2 of 2
      • Hold down the release tabs to remove the cables from the white tabs.
      Ask FixBot
    5. InFocus LP540 Projector Lens Replacement: step 5, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 5, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 5, image 3 of 3
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      Ask FixBot
    6. InFocus LP540 Projector Lens Replacement: step 6, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 6, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 6, image 3 of 3
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      Ask FixBot
    1. InFocus LP540 Projector Lens Replacement, Lens: step 7, image 1 of 2 InFocus LP540 Projector Lens Replacement, Lens: step 7, image 2 of 2
      • Remove the two 10 mm screws using the Philips 0 screwdriver head.
      Ask FixBot
    2. InFocus LP540 Projector Lens Replacement: step 8, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 8, image 2 of 2
      • Carefully hold the lens from both ends and lift up simultaneously
      Ask FixBot
Author
with
Jorge L Navarro
533 Reputation
5 Guides authored
Cal Poly, Team 13-17, Regan Winter 2014 Member of Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 3,349
