Up to 20% off select tools
InFocus LP540 Projector Lamp Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
97
All Time:
3,881
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will assist with replacing a non-functioning projector lamp, which is responsible for providing the light necessary for projection.
    1. InFocus LP540 Projector Lamp Replacement, Lamp: step 1, image 1 of 2 InFocus LP540 Projector Lamp Replacement, Lamp: step 1, image 2 of 2
      • Place the projector on its back with the control buttons facing down.
      • Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
      Ask FixBot
    2. InFocus LP540 Projector Lamp Replacement: step 2, image 1 of 1
      • Use the plastic flat-head to remove the lamp lid.
      Ask FixBot
    3. InFocus LP540 Projector Lamp Replacement: step 3, image 1 of 2 InFocus LP540 Projector Lamp Replacement: step 3, image 2 of 2
      • Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
      • Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
      Ask FixBot
    4. InFocus LP540 Projector Lamp Replacement: step 4, image 1 of 3 InFocus LP540 Projector Lamp Replacement: step 4, image 2 of 3 InFocus LP540 Projector Lamp Replacement: step 4, image 3 of 3
      • Grab the silver handle.
      • Unhook the handle so it can move freely.
      • Pull the handle straight up until the lamp is completely removed from projector.
      Ask FixBot
Author
with
Jorge L Navarro
533 Reputation
5 Guides authored
Cal Poly, Team 13-17, Regan Winter 2014 Member of Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 97
All Time: 3,881
