InFocus IN35W Motherboard Replacement
    1. InFocus IN35W Motherboard Replacement, Top Plate: step 1, image 1 of 3 InFocus IN35W Motherboard Replacement, Top Plate: step 1, image 2 of 3 InFocus IN35W Motherboard Replacement, Top Plate: step 1, image 3 of 3
      • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
      • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
      Ask FixBot
    2. InFocus IN35W Motherboard Replacement: step 2, image 1 of 2 InFocus IN35W Motherboard Replacement: step 2, image 2 of 2
      • Pull the top piece up.
      • The two gray ventilation grates will slip off the device.
      Ask FixBot
    3. InFocus IN35W Motherboard Replacement: step 3, image 1 of 2 InFocus IN35W Motherboard Replacement: step 3, image 2 of 2
      • Detach the white speaker wire that connects the motherboard to the top piece.
      • Remove the top cover from the device.
      Ask FixBot
    1. InFocus IN35W Motherboard Replacement, Motherboard: step 4, image 1 of 2 InFocus IN35W Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Detach all six of the cables and speaker wires from the white connectors on the motherboard.
      Ask FixBot
    2. InFocus IN35W Motherboard Replacement: step 5, image 1 of 2 InFocus IN35W Motherboard Replacement: step 5, image 2 of 2
      • Remove the six 4 mm Torx TR10 screws from the motherboard.
      Ask FixBot
    3. InFocus IN35W Motherboard Replacement: step 6, image 1 of 1
      • Carefully grasp the outsides of the motherboard and pull it up to remove it from the device.
      Ask FixBot
Grace Hubert
608 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 388
