Up to 20% off select tools
InFocus IN35W Fan Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
60
All Time:
520
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The fan is an important part of the InFocus IN35W projector, and if it fails to work, your device could overheat and break. If you do not hear the fan running in your projector, this guide will help you access it to figure out the problem.
    1. InFocus IN35W Fan Replacement, Top Plate: step 1, image 1 of 3 InFocus IN35W Fan Replacement, Top Plate: step 1, image 2 of 3 InFocus IN35W Fan Replacement, Top Plate: step 1, image 3 of 3
      • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
      • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
      Ask FixBot
    2. InFocus IN35W Fan Replacement: step 2, image 1 of 2 InFocus IN35W Fan Replacement: step 2, image 2 of 2
      • Pull the top piece up.
      • The two gray ventilation grates will slip off the device.
      Ask FixBot
    3. InFocus IN35W Fan Replacement: step 3, image 1 of 2 InFocus IN35W Fan Replacement: step 3, image 2 of 2
      • Detach the white speaker wire that connects the motherboard to the top piece.
      • Remove the top cover from the device.
      Ask FixBot
    1. InFocus IN35W Fan Replacement, Motherboard: step 4, image 1 of 2 InFocus IN35W Fan Replacement, Motherboard: step 4, image 2 of 2
      • Detach all six of the cables and speaker wires from the white connectors on the motherboard.
      Ask FixBot
    2. InFocus IN35W Fan Replacement: step 5, image 1 of 2 InFocus IN35W Fan Replacement: step 5, image 2 of 2
      • Remove the six 4 mm Torx TR10 screws from the motherboard.
      Ask FixBot
    3. InFocus IN35W Fan Replacement: step 6, image 1 of 1
      • Carefully grasp the outsides of the motherboard and pull it up to remove it from the device.
      Ask FixBot
    1. InFocus IN35W Fan Replacement, Fan: step 7, image 1 of 2 InFocus IN35W Fan Replacement, Fan: step 7, image 2 of 2
      • The fan is located on the side of the device.
      • Lift the fan up and out of the projector body.
      Ask FixBot
Author
with
Grace Hubert
608 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 60
All Time: 520
