Up to 20% off select tools
InFocus IN35W Daughterboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
59
All Time:
438
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the daughterboard in your InFocus IN35W projector. The daughterboard is a secondary circuit board that is attached to the motherboard. It is very delicate and fragile, and it is important to follow the instructions carefully when altering it. In the case that your projector may be broken, it is important to check the parts of the daughterboard to see if anything may have been altered and appear to be damaged.
    1. InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 1 of 3 InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 2 of 3 InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 3 of 3
      • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
      • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
      Ask FixBot
    2. InFocus IN35W Daughterboard Replacement: step 2, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 2, image 2 of 2
      • Pull the top piece up.
      • The two gray ventilation grates will slip off the device.
      Ask FixBot
    3. InFocus IN35W Daughterboard Replacement: step 3, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 3, image 2 of 2
      • Detach the white speaker wire that connects the motherboard to the top piece.
      • Remove the top cover from the device.
      Ask FixBot
    1. InFocus IN35W Daughterboard Replacement, Daughterboard: step 4, image 1 of 2 InFocus IN35W Daughterboard Replacement, Daughterboard: step 4, image 2 of 2
      • Remove one 7 mm screw from the silver fastening plate using a Torx T9 screwdriver.
      Ask FixBot
    2. InFocus IN35W Daughterboard Replacement: step 5, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 5, image 2 of 2
      • Remove eight 7 mm screws from the daughterboard using a Torx T9 screwdriver.
      Ask FixBot
    3. InFocus IN35W Daughterboard Replacement: step 6, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 6, image 2 of 2
      • Disconnect the red and black bundled cable from its connector on the daughterboard.
      • Grab the daughterboard by the sides and carefully lift it out from the top plate.
      Ask FixBot
Author
with
Grace Hubert
608 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 59
All Time: 438
