InFocus IN3114 LED Touch Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
64
All Time:
457
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The InFocus IN3114 projector uses an LED touch screen to provide users with control over the quality of the image produced.
Consider replacing the board if the LEDs on the board do not light up, or if the buttons on the board are not responsive when pressed.
This guide provides instructions on replacing the LED touch screen for the InFocus IN3114.
No special skills are required to complete this task, and all required tools are listed.
Before beginning the process, turn off the projector, unplug the power cable.
Tools
    1. InFocus IN3114 LED Touch Board Replacement, Top Plate: step 1, image 1 of 2 InFocus IN3114 LED Touch Board Replacement, Top Plate: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
      Ask FixBot
    2. InFocus IN3114 LED Touch Board Replacement: step 2, image 1 of 3 InFocus IN3114 LED Touch Board Replacement: step 2, image 2 of 3 InFocus IN3114 LED Touch Board Replacement: step 2, image 3 of 3
      • Use your hands to slide the top plate off of the projector.
      • Lift and remove the plate.
      Ask FixBot
    1. InFocus IN3114 LED Touch Board Replacement, LED Touch Board: step 3, image 1 of 2 InFocus IN3114 LED Touch Board Replacement, LED Touch Board: step 3, image 2 of 2
      • Use the opening tool to lift the control panel cover.
      • Remove the cover.
      Ask FixBot
    2. InFocus IN3114 LED Touch Board Replacement: step 4, image 1 of 3 InFocus IN3114 LED Touch Board Replacement: step 4, image 2 of 3 InFocus IN3114 LED Touch Board Replacement: step 4, image 3 of 3
      Ask FixBot
Kevin Li
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 64
All Time: 457
