InFocus IN3114 Fans Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
62
All Time:
683
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Use this guide to remove the fans on the left side (from the front) of the InFocus IN3114 projector.
Fans are used to keep devices cool. As computer parts are used, they emit heat. Keeping fans clean, unobstructed, and operable are critical to maintaining a device long-term.
Fans may be broken, obstructed, stuck, or unplugged. More often than not, removing the fans, cleaning them, and replacing the fans is sufficient restoration.
Tools
    1. InFocus IN3114 Fans Replacement, Top Plate: step 1, image 1 of 2 InFocus IN3114 Fans Replacement, Top Plate: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
      Ask FixBot
    2. InFocus IN3114 Fans Replacement: step 2, image 1 of 3 InFocus IN3114 Fans Replacement: step 2, image 2 of 3 InFocus IN3114 Fans Replacement: step 2, image 3 of 3
      • Use your hands to slide the top plate off of the projector.
      • Lift and remove the plate.
      Ask FixBot
    1. InFocus IN3114 Fans Replacement, Lamp: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to unscrew the two 9 mm screws on the top of the lamp housing unit.
      • Screws will not come all the way out. It is best to just loosen them as much as possible.
      Ask FixBot
    2. InFocus IN3114 Fans Replacement: step 4, image 1 of 1
      • Use your hands to pull up on the silver handle and remove the lamp housing unit.
      Ask FixBot
    3. InFocus IN3114 Fans Replacement: step 5, image 1 of 2 InFocus IN3114 Fans Replacement: step 5, image 2 of 2
      • Once the lamp housing is removed flip it over where silver pull tab is face down.
      • Use a Phillips #00 screwdriver to remove the 5 mm screw from the right side of the lamp housing unit.
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws from the top of the unit.
      Ask FixBot
    4. InFocus IN3114 Fans Replacement: step 6, image 1 of 1
      • Use hands to pull off the black unit cover.
      Ask FixBot
    5. InFocus IN3114 Fans Replacement: step 7, image 1 of 2 InFocus IN3114 Fans Replacement: step 7, image 2 of 2
      • Once the cover is removed, flip the housing unit so the bulb is face down.
      • Remove the four 4 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    6. InFocus IN3114 Fans Replacement: step 8, image 1 of 2 InFocus IN3114 Fans Replacement: step 8, image 2 of 2
      • Use hands to pull out the bulb and silver cover.
      • Gently pull on the two wires that connect the bulb to its housing to disconnect them.
      Ask FixBot
    7. InFocus IN3114 Fans Replacement: step 9, image 1 of 2 InFocus IN3114 Fans Replacement: step 9, image 2 of 2
      • Once wires are disconnected, Remove the bulb from the silver cover and replace.
      Ask FixBot
    1. InFocus IN3114 Fans Replacement, Fans: step 10, image 1 of 1
      • Use a Phillips #1 screwdriver to loosen and remove the five 7 mm screws that secure the frame.
      Ask FixBot
    2. InFocus IN3114 Fans Replacement: step 11, image 1 of 1
      • Pull back the top of the front face slightly.
      • Use a Phillips #1 screwdriver to remove the two 7 mm screws, and lift upwards.
      • These screws are held in tightly. In order to prevent stripping, be sure to apply ample downward pressure to the screwdriver when unscrewing the screws.
      Ask FixBot
    3. InFocus IN3114 Fans Replacement: step 12, image 1 of 2 InFocus IN3114 Fans Replacement: step 12, image 2 of 2
      • Use hands to unplug wiring connecting the front face to the main projector.
      • Wiring should pull out with moderate force.
      Ask FixBot
    4. InFocus IN3114 Fans Replacement: step 13, image 1 of 1
      • Carefully pull the left vent back, and use a Phillips #1 screwdriver to remove the screws that secure it in place.
      • These screws are held in tightly. In order to prevent stripping, be sure to apply ample downward pressure.
      Ask FixBot
    5. InFocus IN3114 Fans Replacement: step 14, image 1 of 3 InFocus IN3114 Fans Replacement: step 14, image 2 of 3 InFocus IN3114 Fans Replacement: step 14, image 3 of 3
      • Carefully remove each fan, and use your hands to gently unplug their connectors from the circuit board.
      • The wires should unplug easily with a moderate tug.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 62
All Time: 683
