InFocus IN3104 Top Cover Replacement
    1. InFocus IN3104 Top Cover Replacement, Top Cover: step 1, image 1 of 3 InFocus IN3104 Top Cover Replacement, Top Cover: step 1, image 2 of 3 InFocus IN3104 Top Cover Replacement, Top Cover: step 1, image 3 of 3
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      Ask FixBot
    2. InFocus IN3104 Top Cover Replacement: step 2, image 1 of 3 InFocus IN3104 Top Cover Replacement: step 2, image 2 of 3 InFocus IN3104 Top Cover Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 18
All Time: 539
