InFocus IN3104 Speaker Replacement
    1. InFocus IN3104 Speaker Replacement, Top Cover: step 1, image 1 of 3 InFocus IN3104 Speaker Replacement, Top Cover: step 1, image 2 of 3 InFocus IN3104 Speaker Replacement, Top Cover: step 1, image 3 of 3
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      Ask FixBot
    2. InFocus IN3104 Speaker Replacement: step 2, image 1 of 3 InFocus IN3104 Speaker Replacement: step 2, image 2 of 3 InFocus IN3104 Speaker Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      Ask FixBot
    1. InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 1 of 2 InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
      Ask FixBot
    2. InFocus IN3104 Speaker Replacement: step 4, image 1 of 3 InFocus IN3104 Speaker Replacement: step 4, image 2 of 3 InFocus IN3104 Speaker Replacement: step 4, image 3 of 3
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
      Ask FixBot
    1. InFocus IN3104 Speaker Replacement, Speaker: step 5, image 1 of 2 InFocus IN3104 Speaker Replacement, Speaker: step 5, image 2 of 2
      • Unplug the speaker wire that is located right behind the cooling fan.
      • Use a Phillips #1 screwdriver to remove the two 6 mm screws on the frame brackets.
      Ask FixBot
    2. InFocus IN3104 Speaker Replacement: step 6, image 1 of 3 InFocus IN3104 Speaker Replacement: step 6, image 2 of 3 InFocus IN3104 Speaker Replacement: step 6, image 3 of 3
      • Remove the side panel.
      • Use a Phillips #1 screwdriver to remove the two 6 mm screws.
      • Remove the speaker by pulling it straight out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 509
