Introduction
If your InFocus IN3104 device is overheating very easily the cooling fan may need to be replaced. This may be caused by a buildup of dust on the fan, or the fan just not turning properly. The cooling fan keeps the device at a cool and regulated temperature.
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
Lift up the metal cover and set it aside to reveal the motherboard.
Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
