Up to 20% off select tools
InFocus IN3104 Color Wheel Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
65
All Time:
1,084
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 8 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your InFocus IN3104 has fuzzy or distorted color, this guide is for you. The fuzzy or distorted color most likely means that your color wheel is broken or defective. If your color wheel is broken it will need to be replaced. The color wheel provides color to the projection and is needed for display.
    1. InFocus IN3104 Color Wheel Replacement, Top Cover: step 1, image 1 of 3 InFocus IN3104 Color Wheel Replacement, Top Cover: step 1, image 2 of 3 InFocus IN3104 Color Wheel Replacement, Top Cover: step 1, image 3 of 3
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      Ask FixBot
    2. InFocus IN3104 Color Wheel Replacement: step 2, image 1 of 3 InFocus IN3104 Color Wheel Replacement: step 2, image 2 of 3 InFocus IN3104 Color Wheel Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove 2 screws on the back panel (not pictured)
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      Ask FixBot
    1. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 1 of 2 InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
      Ask FixBot
    2. InFocus IN3104 Color Wheel Replacement: step 4, image 1 of 3 InFocus IN3104 Color Wheel Replacement: step 4, image 2 of 3 InFocus IN3104 Color Wheel Replacement: step 4, image 3 of 3
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
      Ask FixBot
    1. InFocus IN3104 Color Wheel Replacement, Color Wheel: step 5, image 1 of 3 InFocus IN3104 Color Wheel Replacement, Color Wheel: step 5, image 2 of 3 InFocus IN3104 Color Wheel Replacement, Color Wheel: step 5, image 3 of 3
      • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
      Ask FixBot
    2. InFocus IN3104 Color Wheel Replacement: step 6, image 1 of 2 InFocus IN3104 Color Wheel Replacement: step 6, image 2 of 2
      • Carefully lift up the black paper cover. Do not completely remove it from the device.
      • Lift the paper cover up to reveal two 6mm screws.
      Ask FixBot
    3. InFocus IN3104 Color Wheel Replacement: step 7, image 1 of 2 InFocus IN3104 Color Wheel Replacement: step 7, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 6mm screws.
      • Remove the color wheel from the device by lifting it out of the projector.
      Ask FixBot
Author
with
Christopher Held
181 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 65
All Time: 1,084
