In-Ear Headphone Control and Mic Block Disassembly
    1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: step 1, image 1 of 1
      • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
      Ask FixBot
    2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: step 2, image 1 of 1
      • Wedge the tool in the corner and start sliding it to the left.
      • As you do this slowely twist the screw driver back and forth to release the clips.
      • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
      Ask FixBot
    3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: step 3, image 1 of 2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: step 3, image 2 of 2
      • Repeat step 2 and the control unit should open as seen in the image.
      • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
      Ask FixBot
    4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: step 4, image 1 of 1
      • It is quickly seen that one of the wires has broken away from the circuit board (see image)
      Ask FixBot
    5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: step 5, image 1 of 1
      • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
      • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
      • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
      • And they are fixed!
      Ask FixBot
Your headphones should now be working!
6 other people completed this guide.
Alexander
332 Reputation
1 Guide authored
2 Guide Comments
Thanks a lot this worked perfectly thank you very much
MD Ratul - Reply Share
Very good lesson. Thanks a lot...
PK Chatterjee - Reply Share
Past 24 Hours: 9
Past 7 Days: 45
Past 30 Days: 180
All Time: 18,840
