Impuls LED Alarm Clock Radio Disassembly
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
78
All Time:
1,263
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide provides a step-by-step plan for disassembly of the Impuls LED Alarm Clock Radio. The price of the clock radio is relatively low, it is 16.95 euros at bol.com. The guide is made by 5 Industrial Design students at the TU Delft.
Tools
    1. Impuls LED Alarm Clock Radio Disassembly, Impuls LED Alarm Clock Radio Disassembly: step 1, image 1 of 1
      • Unscrew the 4 base screws at the bottom with the Phillips 1 screwdriver.
      Ask FixBot
    2. Impuls LED Alarm Clock Radio Disassembly: step 2, image 1 of 2 Impuls LED Alarm Clock Radio Disassembly: step 2, image 2 of 2
      • Open the top and remove the transparent plastic cap.
      Ask FixBot
    3. Impuls LED Alarm Clock Radio Disassembly: step 3, image 1 of 1
      • Remove the 4 screws from the PCB.
      • It is desirable to use 3 hands because you have to do 3 jobs: screw, hold the top and hold the bottom.
      Ask FixBot
    4. Impuls LED Alarm Clock Radio Disassembly: step 4, image 1 of 2 Impuls LED Alarm Clock Radio Disassembly: step 4, image 2 of 2
      • Remove/unclick 4 plastic buttons.
      • There are 4 different types of buttons.
      Ask FixBot
    5. Impuls LED Alarm Clock Radio Disassembly: step 5, image 1 of 2 Impuls LED Alarm Clock Radio Disassembly: step 5, image 2 of 2
      • Unscrew 2 screws of the radio tuning system.
      Ask FixBot
    6. Impuls LED Alarm Clock Radio Disassembly: step 6, image 1 of 1
      • Remove the gear that protects the cap.
      Ask FixBot
    7. Impuls LED Alarm Clock Radio Disassembly: step 7, image 1 of 1
      • Lift up the small gear.
      Ask FixBot
    8. Impuls LED Alarm Clock Radio Disassembly: step 8, image 1 of 1
      • Lift up the flexible pin rack.
      Ask FixBot
    9. Impuls LED Alarm Clock Radio Disassembly: step 9, image 1 of 1
      • Remove the flexible pin rack holder.
      Ask FixBot
    10. Impuls LED Alarm Clock Radio Disassembly: step 10, image 1 of 1
      • Remove 3 screws of the big PCB.
      Ask FixBot
    11. Impuls LED Alarm Clock Radio Disassembly: step 11, image 1 of 1
      • Remove the backside of the casing.
      Ask FixBot
    12. Impuls LED Alarm Clock Radio Disassembly: step 12, image 1 of 1
      • Remove the grey double gear.
      Ask FixBot
    13. Impuls LED Alarm Clock Radio Disassembly: step 13, image 1 of 1
      • Remove the switch casing.
      Ask FixBot
    14. Impuls LED Alarm Clock Radio Disassembly: step 14, image 1 of 2 Impuls LED Alarm Clock Radio Disassembly: step 14, image 2 of 2
      • Flip the big PCB.
      Ask FixBot
    15. Impuls LED Alarm Clock Radio Disassembly: step 15, image 1 of 1
      • Unscrew 2 screws on the back of the PCB the black gear house.
      Ask FixBot
    16. Impuls LED Alarm Clock Radio Disassembly: step 16, image 1 of 1
      • Remove the black gear housing.
      Ask FixBot
    17. Impuls LED Alarm Clock Radio Disassembly: step 17, image 1 of 1
      • Unscrew 2 screws of the electro magnet.
      Ask FixBot
    18. Impuls LED Alarm Clock Radio Disassembly: step 18, image 1 of 1
      • Lift up the electro magnet.
      Ask FixBot
    19. Impuls LED Alarm Clock Radio Disassembly: step 19, image 1 of 1
      • Unscrew the cap of the POT meter.
      Ask FixBot
    20. Impuls LED Alarm Clock Radio Disassembly: step 20, image 1 of 1
      • Remove the big black double gear.
      Ask FixBot
    21. Impuls LED Alarm Clock Radio Disassembly: step 21, image 1 of 1
      • Remove the hot glue of the antenna.
      Ask FixBot
    22. Impuls LED Alarm Clock Radio Disassembly: step 22, image 1 of 1
      • Remove all the electrical components by desoldering.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 78
All Time: 1,263
