Up to 20% off select tools
Impression i7 USB Port Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
59
All Time:
624
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide details the necessary steps to replace the USB port on the Impression i7. Due to the difficult nature of this replacement, it should only be performed when all other potential options have been exhausted.
    1. Impression i7 USB Port Replacement, Battery: step 1, image 1 of 1
      • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
      Ask FixBot
    2. Impression i7 USB Port Replacement: step 2, image 1 of 1
      • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
      Ask FixBot
    3. Impression i7 USB Port Replacement: step 3, image 1 of 1
      • After the entire perimeter has been pried, remove the back of the device.
      • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
      Ask FixBot
    4. Impression i7 USB Port Replacement: step 4, image 1 of 2 Impression i7 USB Port Replacement: step 4, image 2 of 2
      • Remove the transparent, orange tape from the edge of the battery.
      • Pry the battery off, using the plastic opening tool.
      Ask FixBot
    5. Impression i7 USB Port Replacement: step 5, image 1 of 1
      • Desolder the positive and negative leads.
      Ask FixBot
    6. Impression i7 USB Port Replacement: step 6, image 1 of 2 Impression i7 USB Port Replacement: step 6, image 2 of 2
      • Pull the battery away from the adhesive.
      • Peel the gray tape from the top of the battery.
      Ask FixBot
    1. Impression i7 USB Port Replacement, USB Port: step 7, image 1 of 1
      • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
      Ask FixBot
    2. Impression i7 USB Port Replacement: step 8, image 1 of 2 Impression i7 USB Port Replacement: step 8, image 2 of 2
      • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
      Ask FixBot
    3. Impression i7 USB Port Replacement: step 9, image 1 of 2 Impression i7 USB Port Replacement: step 9, image 2 of 2
      • Desolder the eight solder joints holding the USB Port in place.
      Ask FixBot
Author
with
Cole Beaver
417 Reputation
3 Guides authored
IUPUI, Team S1-G5, Baechle Fall 2018 Member of IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 59
All Time: 624
