Up to 20% off select tools
Impression i7 Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
57
All Time:
549
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide details the necessary steps to remove the front facing camera from the Leader Impression i7 tablet. Make sure you have a replacement camera ready before starting this guide.
    1. Impression i7 Front Camera Replacement, Battery: step 1, image 1 of 1
      • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
      Ask FixBot
    2. Impression i7 Front Camera Replacement: step 2, image 1 of 1
      • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
      Ask FixBot
    3. Impression i7 Front Camera Replacement: step 3, image 1 of 1
      • After the entire perimeter has been pried, remove the back of the device.
      • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
      Ask FixBot
    4. Impression i7 Front Camera Replacement: step 4, image 1 of 2 Impression i7 Front Camera Replacement: step 4, image 2 of 2
      • Remove the transparent, orange tape from the edge of the battery.
      • Pry the battery off, using the plastic opening tool.
      Ask FixBot
    5. Impression i7 Front Camera Replacement: step 5, image 1 of 1
      • Desolder the positive and negative leads.
      Ask FixBot
    6. Impression i7 Front Camera Replacement: step 6, image 1 of 2 Impression i7 Front Camera Replacement: step 6, image 2 of 2
      • Pull the battery away from the adhesive.
      • Peel the gray tape from the top of the battery.
      Ask FixBot
    1. Impression i7 Front Camera Replacement, Front Camera: step 7, image 1 of 1
      • Gently pull the front camera connection out of its socket.
      Ask FixBot
    2. Impression i7 Front Camera Replacement: step 8, image 1 of 1
      • Lift the camera unit from its housing. The unit should come out with minimal force.
      Ask FixBot
Author
with
Cole Beaver
417 Reputation
3 Guides authored
IUPUI, Team S1-G5, Baechle Fall 2018 Member of IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 57
All Time: 549
