Up to 20% off select tools
Impression i7 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
50
All Time:
681
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in your Impression i7. This guide should be used whenever the battery in your device isn't performing as originally intended by the manufacturer.
    1. Impression i7 Battery Replacement, Battery: step 1, image 1 of 1
      • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
      Ask FixBot
    2. Impression i7 Battery Replacement: step 2, image 1 of 1
      • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
      Ask FixBot
    3. Impression i7 Battery Replacement: step 3, image 1 of 1
      • After the entire perimeter has been pried, remove the back of the device.
      • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
      Ask FixBot
    4. Impression i7 Battery Replacement: step 4, image 1 of 2 Impression i7 Battery Replacement: step 4, image 2 of 2
      • Remove the transparent, orange tape from the edge of the battery.
      • Pry the battery off, using the plastic opening tool.
      Ask FixBot
    5. Impression i7 Battery Replacement: step 5, image 1 of 1
      • Desolder the positive and negative leads.
      Ask FixBot
    6. Impression i7 Battery Replacement: step 6, image 1 of 2 Impression i7 Battery Replacement: step 6, image 2 of 2
      • Pull the battery away from the adhesive.
      • Peel the gray tape from the top of the battery.
      Ask FixBot
2 other people completed this guide.
Author
with
Cole Beaver
417 Reputation
3 Guides authored
IUPUI, Team S1-G5, Baechle Fall 2018 Member of IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 50
All Time: 681
