Imation Superdisk USB Drive Plastic Housing Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
90
All Time:
1,496
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace an impaired or degraded plastic housing for your Imation Superdisk USB Drive (Model SD-USB-M2).
The plastic housing functions as a protective barrier for internal components of the Superdisk USB Drive. Damage to the plastic housing may result from age or accidental impact. A damaged housing component may require replacement if you encounter difficulty in connecting the drive to a USB port or discover dislodged internal components.
Tools
    1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: step 1, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: step 1, image 2 of 2
      • Flip the device over so the bottom is facing up.
      • You will know it is the bottom because there will be six silver screws visible.
      Ask FixBot
    2. Imation Superdisk USB Drive Plastic Housing Replacement: step 2, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement: step 2, image 2 of 2
      • Remove the USB converter device by gently pulling it out.
      • Do not pull the converter device out by the cord.
      Ask FixBot
    3. Imation Superdisk USB Drive Plastic Housing Replacement: step 3, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement: step 3, image 2 of 2
      • Remove the six silver screws using a small Phillips head screwdriver.
      Ask FixBot
    4. Imation Superdisk USB Drive Plastic Housing Replacement: step 4, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement: step 4, image 2 of 2
      • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
      • Lift panel free of device.
      Ask FixBot
    5. Imation Superdisk USB Drive Plastic Housing Replacement: step 5, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement: step 5, image 2 of 2
      • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
      • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
      Ask FixBot
    6. Imation Superdisk USB Drive Plastic Housing Replacement: step 6, image 1 of 2 Imation Superdisk USB Drive Plastic Housing Replacement: step 6, image 2 of 2
      • Slide the metal housing out of the plastic shell.
      Ask FixBot
Caitlin Horwatt
137 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 90
All Time: 1,496
