Imation Superdisk USB Drive Metal Casing Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
47
All Time:
893
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: step 1, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: step 1, image 2 of 2
      • Flip the device over so the bottom is facing up.
      • You will know it is the bottom because there will be six silver screws visible.
      Ask FixBot
    2. Imation Superdisk USB Drive Metal Casing Replacement: step 2, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 2, image 2 of 2
      • Remove the USB converter device by gently pulling it out.
      • Do not pull the converter device out by the cord.
      Ask FixBot
    3. Imation Superdisk USB Drive Metal Casing Replacement: step 3, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 3, image 2 of 2
      • Remove the six silver screws using a small Phillips head screwdriver.
      Ask FixBot
    4. Imation Superdisk USB Drive Metal Casing Replacement: step 4, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 4, image 2 of 2
      • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
      • Lift panel free of device.
      Ask FixBot
    5. Imation Superdisk USB Drive Metal Casing Replacement: step 5, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 5, image 2 of 2
      • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
      • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
      Ask FixBot
    6. Imation Superdisk USB Drive Metal Casing Replacement: step 6, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 6, image 2 of 2
      • Slide the metal housing out of the plastic shell.
      Ask FixBot
    1. Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: step 7, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: step 7, image 2 of 2
      • Slide metal panel out of the metal casing.
      Ask FixBot
    2. Imation Superdisk USB Drive Metal Casing Replacement: step 8, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 8, image 2 of 2
      • Slide disk drive out of metal casing.
      Ask FixBot
Ryan
1 Reputation
1 Guide authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 47
All Time: 893
